Strange port forwarding entry.
domic
Does this port forwarding entry sound familiar to anyone else?
A search online didn't find any correlation between the Transmission client software and the port 58172. I'm on firmware 388.2 alpha build.
I don't remember adding this entry myself, but could it maybe be something that changed during 388.x firmware transition? Maybe a deprecated Administration WebGUI HTTP WAN port rule Asus/RMerlin made or something?
"Name: Transmission_ListeningPort
Port: 58172
Internal IP adress: 10.0.0.1"
Try running these commands to see if the source can be found:
Bash:
iptables-save -c -t nat | grep 58172
nvram show 2>/dev/null | grep 58172
grep 58172 /jffs/scripts/firewall-start /jffs/scripts/nat-start
Do you see this on the WAN section or the System Log section, or both?
admin@RT-AX86U /t/h/root# iptables-save -c -t nat | grep 58172
[21:1260] -A VSERVER -p tcp -m tcp --dport 58172 -j DNAT --to-destination 10.0.0.1
[29924:3889932] -A VSERVER -p udp -m udp --dport 58172 -j DNAT --to-destination 10.0.0.1
admin@RT-AX86U /t/h/root# nvram show 2>/dev/null | grep 58172
vts_rulelist=<Transmission_ListeningPort>58172>10.0.0.1>>BOTH>
admin@RT-AX86U /t/h/root# grep 58172 /jffs/scripts/firewall-start /jffs/scripts/nat-start
grep: /jffs/scripts/nat-start: No such file or directory
admin@RT-AX86U /t/h/root [2]# grep 58172 /jffs/scripts/firewall-start
admin@RT-AX86U /t/h/root [1]# grep 58172 /jffs/scripts/* admin@RT-AX86U /t/h/root [1]#
So delete it from the WAN - Virtual Server / Port Forwarding page in the GUI. Let us know if it reappears later.
Port: 58172
Presumably it's left over from when you installed Transmission last year:
