When I connect to my laptop which is on the 5 GHz network from my desktop which is using Gigabit LAN, TeamViewer sometimes stutters, lags, or freezes with the laptop on WiFi, same with when I stream my SDR programs over the network. The client end always stutters. When I use the wired connection, I don't have this problem.
Is there a way that I can reduce latency / lag with the WiFi?
I've checked for interfering networks causing overlap and it's my router on the selected control channel. The channel width on the 5 GHz band is maxed out.
I'm using the RT-AC1900P router with Merlin 386.9 and yeah, I did do a factory reset after upgrading the firmware.
I could just use a wired connection, but it's not my first choice.
