Streaming TV app is location based
Jeffb
Asus RT 5300 AC Router w/Merlin and Express VPN installed,
PSVue will not accept the network connection due to being “location based” Connected to the Chicago server as that is closest. Contacted ExpressVPN with no success.
Am willing to invest in another device as my wireless speed is also limited due to CPU.
Any advice on resolving VPN and protecting network and also increasing speed would be appreciated!?
Thank You
messerchmidt
Build a pfsense pc based router, use asus as a wifi ap. Will solve your problem.
Thank You
thiggins
Mr. Easy
Staff member
Streaming content services have gotten smarter about enforcing country restrictions due to pressure from content owners. Many now detect and block traffic from VPNs.
Jeffb
Thanks, am planning to try Untangle on an I5 Qocom box. Hopefully I can route correctly.
unclebuk
I watch PS-Vue from my location in SE Asia with ExpressVPN (ovpn on Asus AC86U) using Washington, Seattle, NY and LA servers....but there is a caveat with your "home location" and using devices away from your home location, ie; using a vpn server outside your billing address location. Once you set that up with Ps-Vue you will be able to connect.
D Streaming apps and rebooting a router running OpenVPN VPN 5
