SomeWhereOverTheRainBow
Strictly for Academic purpose For those wanting to create their own personal DoT server. It is easy with Asuswrt-Merlin and Entware.
First step: setup a DDNS service. (side note: if you plan on using ipv6 you need a ddns service that supports it such as dynv6)
If you decide to setup with dynv6, here is an adaptation of their IP update script for use on Merlin
/jffs/scripts/dynv6.sh
chmod 755 /jffs/scripts/dynv6.sh
You can pass it off in cru
the argument must look like
(token=##some key they give you) /jffs/scripts/dynv6.sh (DDNS address)
nano /jffs/scripts/ddns-start
chmod 755 /jffs/scripts/ddns-start
nano /jffs/inadyn.conf
chmod 755 /jffs/inadyn.conf
This guide can be followed for setting up the basic nginx proxy:
Simply install nginx using opkg install nginx-extras
Instead of the nginx package specified inside the tutorial link (side note: you may have to choose the latest supported PHP package since the one in the guide is a bit dated.)
use the rest of the guide to setup your basic nginx.conf
after that is configured to your liking, simply add this script to the bottom of your nginx.conf:
You need to add a few lines to the bottom your /jffs/scripts/firewall-start
After all this is done- you can take your own DoT server for a spin simply by adding your DDNS address to your Smartphone DNS-Privacy option. Give it a test.
(#Let it be noted this is strictly for Academic)
#!/bin/sh -e
hostname=$1
device=$2
file=$HOME/.dynv6.addr6
[ -e $file ] && old=`cat $file`
if [ -z "$hostname" -o -z "$token" ]; then
echo "Usage: token=<your-authentication-token> [netmask=64] $0 your-name.dynv6.net [device]"
exit 1
fi
if [ -z "$netmask" ]; then
netmask=128
fi
if [ -n "$device" ]; then
device="dev $device"
fi
address=$(ip -6 addr list scope global $device | grep -v " fd" | sed -n 's/.*inet6 \([0-9a-f:]\+\).*/\1/p' | head -n 1)
if [ -e /usr/sbin/curl ]; then
bin="curl -fsS"
elif [ -e /usr/sbin/wget ]; then
bin="wget -O-"
else
echo "neither curl nor wget found"
exit 1
fi
if [ -z "$address" ]; then
echo "no IPv6 address found"
exit 1
fi
# address with netmask
current=$address/$netmask
if [ "$old" = "$current" ]; then
echo "IPv6 address unchanged"
exit
fi
# send addresses to dynv6
$bin "http://dynv6.com/api/update?hostname=$hostname&ipv6=$current&token=$token"
$bin "http://ipv4.dynv6.com/api/update?hostname=$hostname&ipv4=auto&token=$token"
# save current address
echo $current > $file
#!/bin/sh
inadyn --once -f "/jffs/inadyn.conf" -e "/sbin/ddns_custom_updated 1" --continue-on-error "/sbin/ddns_custom_updated 1"
iterations = 1
provider dynv6.com {
username = YourTokenKey
password = n/a
hostname = { YourHostName.dynv6.net }
secure-ssl = false
load_module "/opt/lib/nginx/ngx_stream_module.so";
stream {
server {
listen *:853 ssl;
proxy_pass 127.0.0.1:53; #you can change this to match your router IP such as 192.168.1.1:53;
proxy_connect_timeout 1s;
preread_timeout 2s;
#uncomment for ipv6 segment
# server {
# listen [::]:853 ssl;
# proxy_pass [::1]:53; #you can change this to match your LAN ipv6 address such as [IPV6address::1]:53;
# proxy_connect_timeout 1s;
# preread_timeout 2s;
ssl_certificate /jffs/.le/(YOUR-DDNS-ADDRESS)/fullchain.pem;
ssl_certificate_key /jffs/.le/(YOUR-DDNS-ADDRESS)/(YOU-DDNS-ADDRESS).key;
ssl_session_timeout 1d;
ssl_session_tickets off;
ssl_protocols TLSv1.2 TLSv1.3;
ssl_prefer_server_ciphers on;
# If you're new enough to support DoT you're new enough not to support old broken ciphers
ssl_ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256;
ssl_session_cache shared:DoT:10m;
log_format dot '$remote_addr\t-\t-\t[$time_local]\t$ssl_protocol\t'
'$ssl_session_reused\t$ssl_cipher\t$ssl_server_name\t$status\t'
'$bytes_sent\t$bytes_received';
access_log /opt/var/log/nginx/dot.log dot;
iptables -I INPUT -p tcp --dport 853 -j ACCEPT
ip6tables -I INPUT -p tcp --dport 853 -j ACCEPT #use only if you setup IPV6 with your DDNS service.
