As QNAP discontinues support for older systems the 219P II being one of them. It continues to work with no issues. What does it mean in general terms? security? I mainly use it for LAN backups but I do tunnel in via FTP periodically when travelling using SFTP. I would assume updates on my router are the important ones for overall LAN health. ( I don't have enough router CPU power to run a VPN at a reasonable speed and have though of putting something together at some point)
I plan to continue with the QNAP till it gives me reason to replace it with either a newer NAS or build a NAS (I ran FreeNAS at one point).
As a side note would a built up Micro-ATX box be a solid choice to run VPN and as a NAS?
