Suppress "Custom Script Running" messages?
ScottW
I'm using Merlin 380.57 on an N66U.
I recently implemented a custom dhcpc-event script to log "bound" events. That works great.
But every time the script is called, the firmware posts an informational message to the system log, like this one:
Mar 4 12:39:02 custom script: Running /jffs/scripts/dhcpc-event (args: ra-updated)
The router advertisement event (args: ra-updated) occurs about every 45 seconds. I understand that is normal, and my script ignores that event -- it only processes the "bound" events.
But the log is being flooded by the informational messages just saying that the script was called for each ra-updated event. For example:
Mar 4 12:35:54 custom script: Running /jffs/scripts/dhcpc-event (args: ra-updated)
Mar 4 12:36:25 custom script: Running /jffs/scripts/dhcpc-event (args: ra-updated)
Mar 4 12:36:56 custom script: Running /jffs/scripts/dhcpc-event (args: ra-updated)
Mar 4 12:37:28 custom script: Running /jffs/scripts/dhcpc-event (args: ra-updated)
Mar 4 12:37:59 custom script: Running /jffs/scripts/dhcpc-event (args: ra-updated)
Mar 4 12:38:31 custom script: Running /jffs/scripts/dhcpc-event (args: ra-updated)
Is there any way to suppress this particular message? It's great for debugging (i.e., making sure the script was called for an event), but it's filling up the log. I suppose I could turn off RA, but would rather have it functioning.
You cannot remove these, unless you modify the firmware's source code and recompile it.
