mindfrost82
I setup my RT-AX88U the other day and initially my Surface Laptop 3 would connect on AX, and continued to use AX after flashing to Merlin Firmware.
Going through the forums, I made all the usual tweak suggestions (set control channels for 2.4GHz & 5GHz, disabled Airtime Fairness, disabled Universal Beamforming, etc).
At some point during the tweaks, my Surface Laptop 3 will only connect to AC (according to the Win10 WiFi properties and according to the RT-AX88U).
I have 160MHz enabled since the Intel AX201 supports it.
I'm not sure if there's a specific setting that caused this. I've tried undoing changes one-by-one but it continues to only connect on AC.
EDIT: It's worth noting that the two iPhone 11 Pro's we have in the house show they're still using AX, so it appears to only be the Surface Laptop 3 with the Intel AX201 card. I also installed the latest driver from Intel's site.
Any thoughts on this or suggestions to try?
