Surfshark VPN Connection Error on stable Merlin 384.19 AC86U
9528
Hi all,
Been using the same UDP file from surfshark for a while(on 384.18) until I flashed it to 384.19. Since yesterday, it started showing connection error.
Been through all troubleshooting with Surfshark support and unable to solve the issue.
Any help will be much appreciated.
Look at the system log, it will tell you what's wrong.
This is what's under General log.
Aug 21 14:31:01 ntpd: Initial clock set
Aug 21 14:31:02 rc_service: ntpd_synced 2911:notify_rc restart_diskmon
Aug 21 14:31:02 disk_monitor: Finish
Aug 21 14:31:02 start_ddns: update WWW.ASUS.COM update@asus.com, wan_unit 0
Aug 21 14:31:02 disk_monitor: be idle
Aug 21 14:31:02 inadyn[2923]: In-a-dyn version 2.7 -- Dynamic DNS update client.
Aug 21 14:31:02 inadyn[2923]: Update forced for alias A9E21A07518B992A65526C16658CCF2F1.asuscomm.com, new IP# 100.80.64.89
Aug 21 14:31:03 inadyn[2923]: Updating cache for A9E21A07518B992A65526C16658CCF2F1.asuscomm.com
Aug 21 14:31:04 kernel: SHN Release Version: 2.0.1 890c91d
Aug 21 14:31:04 kernel: UDB Core Version: 0.2.18
Aug 21 14:31:04 kernel: sizeof forward pkt param = 280
Aug 21 14:31:04 BWDPI: fun bitmap = 47f
Aug 21 14:31:04 kernel: The For ALL DEVICES flag of Prof 1 has been set to ENABLE
Aug 21 14:31:05 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Aug 21 14:31:05 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Aug 21 14:31:05 kernel: HTB: quantum of class 10002 is big. Consider r2q change.
Aug 21 14:31:05 kernel: HTB: quantum of class 10060 is big. Consider r2q change.
Aug 21 14:31:05 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Aug 21 14:31:05 kernel: HTB: quantum of class 20002 is big. Consider r2q change.
Aug 21 14:31:05 kernel: HTB: quantum of class 20060 is big. Consider r2q change.
Aug 21 14:31:05 dhcp_client: bound 100.80.64.89/255.255.240.0 via 100.80.79.254 for 1376 seconds.
Aug 21 14:31:07 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -45dbm) for client [AC:5D:5C:BA:CC:97](rssi: -68dbm) to roam
Aug 21 14:31:07 roamast: eth5: disconnect weak signal strength station [ac:5d:5c:ba:cc:97]
Aug 21 14:31:07 roamast: eth5: remove client [ac:5d:5c:ba:cc:97] from monitor list
Aug 21 14:31:07 wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind AC:5D:5C:BA:CC:97, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Aug 21 14:31:07 wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind AC:5D:5C:BA:CC:97, status: 0, reason: Class 3 frame received from nonassociated station (7)
Aug 21 14:31:32 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -47dbm) for client [38:E6:0A:AB:4B:DF](rssi: -60dbm) to roam
Aug 21 14:31:32 roamast: Roam a client [38:E6:0A:AB:4B:DF], status [0]
Aug 21 14:31:57 crond[1276]: time disparity of 1208064 minutes detected
Aug 21 14:32:35 rc_service: rc 3921:notify_rc restart_wrs
Aug 21 14:32:35 BWDPI: fun bitmap = 47f
Aug 21 14:32:35 kernel: The For ALL DEVICES flag of Prof 1 has been set to ENABLE
Aug 21 14:33:02 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -62dbm) for client [28:FF:3C:1E:FD:2A](rssi: -73dbm) to roam
Aug 21 14:33:02 roamast: Roam a client [28:FF:3C:1E:FD:2A], status [0]
Aug 21 14:33:11 wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind 00:9E:C8:31:3F:43, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Aug 21 14:33:11 wlceventd: WLCEVENTD wlceventd_proc_event(481): eth5: Disassoc 00:9E:C8:31:3F:43, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Aug 21 14:33:12 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -62dbm) for client [28:FF:3C:1E:FD:2A](rssi: -74dbm) to roam
Aug 21 14:33:12 roamast: Roam a client [28:FF:3C:1E:FD:2A], status [0]
Aug 21 14:33:17 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -62dbm) for client [28:FF:3C:1E:FD:2A](rssi: -74dbm) to roam
Aug 21 14:33:17 roamast: Roam a client [28:FF:3C:1E:FD:2A], status [0]
Aug 21 14:33:22 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -63dbm) for client [28:FF:3C:1E:FD:2A](rssi: -74dbm) to roam
Aug 21 14:33:22 roamast: Roam a client [28:FF:3C:1E:FD:2A], status [0]
Aug 21 14:34:02 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -48dbm) for client [38:E6:0A:AB:4B:DF](rssi: -60dbm) to roam
Aug 21 14:34:02 roamast: Roam a client [38:E6:0A:AB:4B:DF], status [0]
Aug 21 14:34:07 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -48dbm) for client [38:E6:0A:AB:4B:DF](rssi: -60dbm) to roam
Aug 21 14:34:07 roamast: Roam a client [38:E6:0A:AB:4B:DF], status [0]
Aug 21 14:34:27 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -47dbm) for client [38:E6:0A:AB:4B:DF](rssi: -59dbm) to roam
Aug 21 14:34:27 roamast: Roam a client [38:E6:0A:AB:4B:DF], status [0]
Aug 21 14:34:37 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -47dbm) for client [38:E6:0A:AB:4B:DF](rssi: -60dbm) to roam
Aug 21 14:34:37 roamast: Roam a client [38:E6:0A:AB:4B:DF], status [0]
Aug 21 14:34:42 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -48dbm) for client [38:E6:0A:AB:4B:DF](rssi: -60dbm) to roam
Aug 21 14:34:42 roamast: Roam a client [38:E6:0A:AB:4B:DF], status [0]
Aug 21 14:34:52 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -47dbm) for client [38:E6:0A:AB:4B:DF](rssi: -59dbm) to roam
Aug 21 14:34:52 roamast: Roam a client [38:E6:0A:AB:4B:DF], status [0]
Aug 21 14:35:02 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -48dbm) for client [38:E6:0A:AB:4B:DF](rssi: -59dbm) to roam
Aug 21 14:35:02 roamast: Roam a client [38:E6:0A:AB:4B:DF], status [0]
Aug 21 14:35:12 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -49dbm) for client [38:E6:0A:AB:4B:DF](rssi: -61dbm) to roam
Aug 21 14:35:12 roamast: Roam a client [38:E6:0A:AB:4B:DF], status [0]
Aug 21 14:44:08 dnsmasq-dhcp[1268]: Ignoring domain ahlnet.local for DHCP host name RVILAP001
Aug 21 14:48:57 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -63dbm) for client [28:FF:3C:1E:FD:2A](rssi: -74dbm) to roam
Aug 21 14:48:57 roamast: Roam a client [28:FF:3C:1E:FD:2A], status [0]
Aug 21 14:49:07 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -63dbm) for client [28:FF:3C:1E:FD:2A](rssi: -75dbm) to roam
Aug 21 14:49:07 roamast: Roam a client [28:FF:3C:1E:FD:2A], status [0]
Aug 21 14:49:17 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -63dbm) for client [28:FF:3C:1E:FD:2A](rssi: -75dbm) to roam
Aug 21 14:49:17 roamast: Roam a client [28:FF:3C:1E:FD:2A], status [0]
Aug 21 14:49:18 wlceventd: WLCEVENTD wlceventd_proc_event(481): eth6: Disassoc 28:FF:3C:1E:FD:2A, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Aug 21 14:49:27 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -63dbm) for client [28:FF:3C:1E:FD:2A](rssi: -75dbm) to roam
Aug 21 14:49:27 roamast: Roam a client [28:FF:3C:1E:FD:2A], status [0]
Aug 21 14:57:08 wlceventd: WLCEVENTD wlceventd_proc_event(500): eth5: Auth 34:CE:00:EA:12:9A, status: Successful (0)
Aug 21 14:57:08 wlceventd: WLCEVENTD wlceventd_proc_event(529): eth5: Assoc 34:CE:00:EA:12:9A, status: Successful (0)
Aug 21 14:57:10 wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind 34:CE:00:EA:12:9A, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Aug 21 14:57:10 wlceventd: WLCEVENTD wlceventd_proc_event(481): eth5: Disassoc 34:CE:00:EA:12:9A, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Aug 21 14:57:12 wlceventd: WLCEVENTD wlceventd_proc_event(500): eth5: Auth 34:CE:00:EA:12:9A, status: Successful (0)
Aug 21 14:57:12 wlceventd: WLCEVENTD wlceventd_proc_event(529): eth5: Assoc 34:CE:00:EA:12:9A, status: Successful (0)
Aug 21 15:23:36 rc_service: httpd 1278:notify_rc start_vpnclient1
Aug 21 15:23:36 ovpn-client1[10067]: Options error: You must define CA file (--ca) or CA path (--capath)
Aug 21 15:23:36 ovpn-client1[10067]: Use --help for more information.
Aug 21 15:23:36 openvpn: Starting OpenVPN client 1 failed!
Aug 21 15:24:15 rc_service: httpd 1278:notify_rc restart_vpnclient1
Aug 21 15:24:16 ovpn-client1[10252]: Options error: You must define CA file (--ca) or CA path (--capath)
Aug 21 15:24:16 ovpn-client1[10252]: Use --help for more information.
Aug 21 15:24:16 openvpn: Starting OpenVPN client 1 failed!
Aug 21 15:24:36 rc_service: httpd 1278:notify_rc start_vpnclient1
Aug 21 15:24:36 ovpn-client1[10424]: Options error: You must define CA file (--ca) or CA path (--capath)
Aug 21 15:24:36 ovpn-client1[10424]: Use --help for more information.
Aug 21 15:24:36 openvpn: Starting OpenVPN client 1 failed!
Aug 21 15:25:37 rc_service: httpd 1278:notify_rc start_vpnclient1
Aug 21 15:25:37 ovpn-client1[10911]: Options error: You must define CA file (--ca) or CA path (--capath)
Aug 21 15:25:37 ovpn-client1[10911]: Use --help for more information.
Aug 21 15:25:37 openvpn: Starting OpenVPN client 1 failed!
Aug 21 15:26:01 openvpn: Resetting client (unit 1) to default settings
Aug 21 15:27:28 rc_service: httpd 1278:notify_rc restart_vpnclient1
Aug 21 15:27:29 ovpn-client1[11773]: Options error: You must define CA file (--ca) or CA path (--capath)
Aug 21 15:27:29 ovpn-client1[11773]: Use --help for more information.
Aug 21 15:27:29 openvpn: Starting OpenVPN client 1 failed!
Aug 21 15:28:04 rc_service: httpd 1278:notify_rc start_vpnclient1
Aug 21 15:28:04 ovpn-client1[12072]: Options error: You must define CA file (--ca) or CA path (--capath)
Aug 21 15:28:04 ovpn-client1[12072]: Use --help for more information.
Aug 21 15:28:04 openvpn: Starting OpenVPN client 1 failed!
Aug 21 15:30:08 wlceventd: WLCEVENTD wlceventd_proc_event(500): eth5: Auth CC:F9:57:FF:D4:25, status: Successful (0)
Aug 21 15:30:08 wlceventd: WLCEVENTD wlceventd_proc_event(529): eth5: Assoc CC:F9:57:FF:D4:25, status: Successful (0)
Aug 21 15:30:27 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -55dbm) for client [CC:F9:57:FF:D4:25](rssi: -71dbm) to roam
Aug 21 15:30:27 roamast: eth5: disconnect weak signal strength station [cc:f9:57:ff:d4:25]
Aug 21 15:30:27 roamast: eth5: remove client [cc:f9:57:ff:d4:25] from monitor list
Aug 21 15:30:27 wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind CC:F9:57:FF:D4:25, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Aug 21 15:30:31 wlceventd: WLCEVENTD wlceventd_proc_event(500): eth5: Auth CC:F9:57:FF:D4:25, status: Successful (0)
Aug 21 15:30:31 wlceventd: WLCEVENTD wlceventd_proc_event(529): eth5: Assoc CC:F9:57:FF:D4:25, status: Successful (0)
Aug 21 15:30:52 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -55dbm) for client [CC:F9:57:FF:D4:25](rssi: -70dbm) to roam
Aug 21 15:30:52 roamast: eth5: disconnect weak signal strength station [cc:f9:57:ff:d4:25]
Aug 21 15:30:52 roamast: eth5: remove client [cc:f9:57:ff:d4:25] from monitor list
Aug 21 15:30:52 wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind CC:F9:57:FF:D4:25, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Aug 21 15:30:54 wlceventd: WLCEVENTD wlceventd_proc_event(500): eth5: Auth CC:F9:57:FF:D4:25, status: Successful (0)
Aug 21 15:30:54 wlceventd: WLCEVENTD wlceventd_proc_event(529): eth5: Assoc CC:F9:57:FF:D4:25, status: Successful (0)
Aug 21 15:31:12 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -55dbm) for client [CC:F9:57:FF:D4:25](rssi: -71dbm) to roam
Aug 21 15:31:12 roamast: eth5: disconnect weak signal strength station [cc:f9:57:ff:d4:25]
Aug 21 15:31:12 roamast: eth5: remove client [cc:f9:57:ff:d4:25] from monitor list
Aug 21 15:31:12 wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind CC:F9:57:FF:D4:25, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Aug 21 15:31:16 wlceventd: WLCEVENTD wlceventd_proc_event(500): eth5: Auth CC:F9:57:FF:D4:25, status: Successful (0)
Aug 21 15:31:16 wlceventd: WLCEVENTD wlceventd_proc_event(529): eth5: Assoc CC:F9:57:FF:D4:25, status: Successful (0)
Aug 21 15:31:37 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -55dbm) for client [CC:F9:57:FF:D4:25](rssi: -70dbm) to roam
Aug 21 15:31:37 roamast: eth5: disconnect weak signal strength station [cc:f9:57:ff:d4:25]
Aug 21 15:31:37 roamast: eth5: remove client [cc:f9:57:ff:d4:25] from monitor list
Aug 21 15:31:37 wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind CC:F9:57:FF:D4:25, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Aug 21 15:31:41 wlceventd: WLCEVENTD wlceventd_proc_event(500): eth5: Auth CC:F9:57:FF:D4:25, status: Successful (0)
Aug 21 15:31:41 wlceventd: WLCEVENTD wlceventd_proc_event(529): eth5: Assoc CC:F9:57:FF:D4:25, status: Successful (0)
Aug 21 15:31:47 rc_service: httpd 1278:notify_rc restart_vpnclient1
Aug 21 15:31:47 ovpn-client1[13796]: Options error: You must define CA file (--ca) or CA path (--capath)
Aug 21 15:31:47 ovpn-client1[13796]: Use --help for more information.
Aug 21 15:31:47 openvpn: Starting OpenVPN client 1 failed!
Aug 21 15:32:02 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -55dbm) for client [CC:F9:57:FF:D4:25](rssi: -70dbm) to roam
Aug 21 15:32:02 roamast: eth5: disconnect weak signal strength station [cc:f9:57:ff:d4:25]
Aug 21 15:32:02 roamast: eth5: remove client [cc:f9:57:ff:d4:25] from monitor list
Aug 21 15:32:03 wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind CC:F9:57:FF:D4:25, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Aug 21 15:32:28 wlceventd: WLCEVENTD wlceventd_proc_event(500): eth5: Auth CC:F9:57:FF:D4:25, status: Successful (0)
Aug 21 15:32:28 wlceventd: WLCEVENTD wlceventd_proc_event(529): eth5: Assoc CC:F9:57:FF:D4:25, status: Successful (0)
Aug 21 15:35:52 rc_service: httpd 1278:notify_rc restart_vpnclient1;restart_dnsmasq
Aug 21 15:35:52 ovpn-client1[15718]: Options error: You must define CA file (--ca) or CA path (--capath)
Aug 21 15:35:52 ovpn-client1[15718]: Use --help for more information.
Aug 21 15:35:52 openvpn: Starting OpenVPN client 1 failed!
Aug 21 15:46:58 wlceventd: WLCEVENTD wlceventd_proc_event(500): eth6: Auth 2C:78:0E:C3:D9:8A, status: Successful (0)
Aug 21 15:46:58 wlceventd: WLCEVENTD wlceventd_proc_event(510): eth6: ReAssoc 2C:78:0E:C3:D9:8A, status: Successful (0)
Aug 21 15:47:29 wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind CC:F9:57:FF:D4:25, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Aug 21 15:47:29 wlceventd: WLCEVENTD wlceventd_proc_event(481): eth5: Disassoc CC:F9:57:FF:D4:25, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Aug 21 15:48:20 wlceventd: WLCEVENTD wlceventd_proc_event(500): eth5: Auth CC:F9:57:FF:D4:25, status: Successful (0)
Aug 21 15:48:20 wlceventd: WLCEVENTD wlceventd_proc_event(529): eth5: Assoc CC:F9:57:FF:D4:25, status: Successful (0)
Aug 21 15:50:57 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -63dbm) for client [2C:78:0E:C3:D9:8A](rssi: -75dbm) to roam
Aug 21 15:50:57 roamast: Roam a client [2C:78:0E:C3:D9:8A], status [0]
Aug 21 15:50:58 wlceventd: WLCEVENTD wlceventd_proc_event(481): eth6: Disassoc 2C:78:0E:C3:D9:8A, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Aug 21 15:56:30 wlceventd: WLCEVENTD wlceventd_proc_event(500): eth5: Auth 2C:78:0E:C3:D9:8A, status: Successful (0)
Aug 21 15:56:30 wlceventd: WLCEVENTD wlceventd_proc_event(510): eth5: ReAssoc 2C:78:0E:C3:D9:8A, status: Successful (0)
Aug 21 15:56:51 wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind 2C:78:0E:C3:D9:8A, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Aug 21 15:56:51 wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind 2C:78:0E:C3:D9:8A, status: 0, reason: Class 3 frame received from nonassociated station (7)
Aug 21 15:56:58 wlceventd: WLCEVENTD wlceventd_proc_event(481): eth5: Disassoc 2C:78:0E:C3:D9:8A, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Aug 21 15:57:33 wlceventd: WLCEVENTD wlceventd_proc_event(500): eth6: Auth 2C:78:0E:C3:D9:8A, status: Successful (0)
Aug 21 15:57:33 wlceventd: WLCEVENTD wlceventd_proc_event(510): eth6: ReAssoc 2C:78:0E:C3:D9:8A, status: Successful (0)
Aug 21 16:12:12 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -47dbm) for client [2C:78:0E:C3:D9:8A](rssi: -71dbm) to roam
Aug 21 16:12:12 roamast: Roam a client [2C:78:0E:C3:D9:8A], status [0]
Aug 21 16:12:12 wlceventd: WLCEVENTD wlceventd_proc_event(481): eth6: Disassoc 2C:78:0E:C3:D9:8A, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Aug 21 16:12:13 roamast: [EXAP]Deauth old sta in 1 0: 2C:78:0E:C3:D9:8A
Aug 21 16:12:13 roamast: eth6: disconnect weak signal strength station [2c:78:0e:c3:d9:8a]
Aug 21 16:12:13 roamast: eth6: remove client [2c:78:0e:c3:d9:8a] from monitor list
Aug 21 16:19:42 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -38dbm) for client [34:CE:00:EA:12:9A](rssi: -61dbm) to roam
Aug 21 16:19:42 roamast: eth5: disconnect weak signal strength station [34:ce:00:ea:12:9a]
Aug 21 16:19:42 roamast: eth5: remove client [34:ce:00:ea:12:9a] from monitor list
Aug 21 16:19:42 wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind 34:CE:00:EA:12:9A, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Aug 21 17:18:07 wlceventd: WLCEVENTD wlceventd_proc_event(500): eth6: Auth 2C:78:0E:C3:D9:8A, status: Successful (0)
Aug 21 17:18:07 wlceventd: WLCEVENTD wlceventd_proc_event(510): eth6: ReAssoc 2C:78:0E:C3:D9:8A, status: Successful (0)
Aug 21 17:19:12 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -49dbm) for client [2C:78:0E:C3:D9:8A](rssi: -75dbm) to roam
Aug 21 17:19:12 roamast: Roam a client [2C:78:0E:C3:D9:8A], status [0]
Aug 21 17:19:13 wlceventd: WLCEVENTD wlceventd_proc_event(481): eth6: Disassoc 2C:78:0E:C3:D9:8A, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Aug 21 17:19:22 roamast: determine candidate node [A8:5E:45:89:C9:80](rssi: -49dbm) for client [2C:78:0E:C3:D9:8A](rssi: -75dbm) to roam
Aug 21 17:19:22 roamast: Roam a client [2C:78:0E:C3:D9:8A], status [0]
You're missing the Certificate Authority on the Certificate page.
