Diversion Swap File Creation Failure on RT-BE86U (amtm fd)
HappyCamper
Hardware: ASUS RT-BE86U
Firmware: Asuswrt-Merlin 3006.102.5 (WiFi 7 Branch)
Storage: USB 3.0 Flash Drive (SanDisk)
The Issue:During the initial amtm -> fd (Format Disk) procedure, I selected "Yes" to create a 2GB Swap File. The script appeared to complete successfully, but no swap file was actually created on the partition.
Symptoms:
  1. Installing Diversion immediately after formatting caused a dnsmasq crash / Out of memory kill event because the system ran out of RAM loading the blocklist.
  2. The issue persisted through multiple re-installs and re-formats using fd.
  3. The root cause was confirmed when I ran the Skynet installer (2), which correctly detected "No Swap File Found" and successfully created one. Once Skynet created the swap, Diversion became stable.
Conclusion:The fd script on the BE86U (aarch64/3006 codebase) seems to fail to commit the swap file generation step, even when confirmed by the user.
