Swap Memory
What is the proper way to create a swap partition on the ac66u?
If you can spare a whole device (disk), it's very easy, note the device names are just examples, you can find your own by blkid, hdparm, partprobe, parted, etc tool (some of these are not installed by default, installation is with ipkg, for example ipkg info hdparm, ipkg install hdparm).
An old USB key is great for this provided it's fast enough
$ swapon /dev/sdb
If you already have a partition type 82 Linux Swap, either
$ swapon /dev/sdb1
or if your partition has a label
$ swapon -L label
If not, create wanted partition(s) with parted etc tool, or even Easeus Partition Master on your Windows PC.
$ swapon /dev/sdb
$ swapon /dev/sdb1
$ swapon -L label
@fearlegendz Please note that this will not survive a reboot...
