Happens to all my routers RT-AC68U, RT-AC1900, ART-C3100 and RT-AC5300 running on the latest firmware 384.12 and most likely not related to Merlin's Firmware at all and some issue with Asus's Wizard design.
If I switch from Wireless Router Mode to Access Point I get the Asus Wizard and fill in some data. I have tried Automatic IP and Manual IP it does not matter, what happens is I am no longer able to connect to the Router though the normal means the Lan Port to continue configuring it.
I keep reseting to factory and start all over again trying Automatic, Manual etc. I wonder if I need to put in a specific change to the MacBookPro Ethernet settings such as changing it from DHCP to something else to make the connections to the router as Access Point?
Does anyone have a link on what setting should be entered into the Asus Wizard to be able to get connections to the router to continue configuring it or modifications that need to be done on the client PC connecting to the router?
Thanks!
Solved downloaded Asus Device Discovery Tool and it immediately connected to the router. Without this tools there is no other way to connect unless anyone has suggestions of other ways. I know one other way is to place it within the network then I can connect to it that way though the browser but I would like to connect to it through the lan port and complete the configuration.
Well after really looking more carefully I see the Ethernet keeps connecting then disconnecting so there must be some further configuration needed for the Ethernet on the Client PC connecting to the router. If I turn off the PC wifi even the Asus Device Discovery Tool connected then disconnects but if I leave the WIFI on the PC the Asus tool will force connect and remain connected.
Thanks!
