tl;dr Where do I put the routing rules via the GUI?
I am attempting to run 3 instances of OpenVPN server and have clients coming in over the WAN to access LAN resources and to force all traffic through the OpenVPN server including Internet access. I have set up the following.
push redirect-gateway def1, the VPN stops working. I believe I need to set a route back from the Synology to the Asus.
Where do I do this on the Asus? Thanks.
- OpenVPN directly on the Asus router (192.168.1.1) using port 80 and 443
- OpenVPN on a Synology (192.168.1.x) in the LAN side of the Asus router using standard port
- The Synology OpenVPN assigns an address of 172.20.x.x)
