TheLostSwede
Synology revealed its new RT2600ac router at Computex this week and below is a quick look at what to expect.
Design wise the RT2600ac looks similar to other manufacturers AC2600 models with four fairly large, removable antennas spread across three sides of the router. There's a front mounted full-size SD card slot, as well as a USB 3.0 port on the left hand side.
Around the back it looks quite empty, with a power switch by the power connector, a single USB 2.0 port, a WAN port and four LAN ports. Note that the first LAN port can be re-purposed as a WAN port and this is simply done using the web UI. The RT2600ac also supports fail-over, either via the second WAN port, or via a 3G/4G dongle inserted into one of the USB ports. This is all easily configurable in the web UI.
One small snag is that the "stand" is not removable, yet there are wall mounting holes on the bottom of the RT2600ac. Hopefully Synology will fix this before they launch the product, or there's a risk there will be some upset customers.
The RT2600ac is based on Qualcomm hardware, but Synology didn't reveal any specifics beyond it being a 1.7GHz dual-core SoC and the fact that this is a second generation MU-MIMO router.
Synology is expecting to launch the RT2600ac towards the end of the year, at an unknown price point.
