Marko Polo
Hi there,
I have a weird time inconsistency which apps write to standard log. For example, transmission writes some false time, which doesn't correspond to system one:
It is obviously wrong that 13.47 goes after 16.47. Where Transmission takes this stuff? System date is fetched by NTP finely, and date function in console also returns correct date.
Again, it seems that USB sub-system lives its own life, not related to others:
Why 1st of August? WTF?
It is very cumbersome to troubleshoot without knowing real event time.
Jul 28 16:47:27 host dropbear[26782]: Child connection from XXXXXXXXXXXXXX
Jul 28 16:47:28 host dropbear[26782]: Pubkey auth succeeded for 'Polo' with key sha1!!
Jul 28 13:47:50 host transmission-daemon[1997]: El Elegido (2016) 1080p Could not connect to tracker (announcer.c:995)
Jul 28 13:47:50 host transmission-daemon[1997]: El Elegido (2016) 1080p Retrying announce in 7205 seconds. (announcer.c:1004)
Jul 28 13:48:03 host transmission-daemon[1997]: The Homesman 2014 720p Bluray DTS x264 Worldwide7477 Could not connect to tracker (announcer.c:995)
Jul 28 13:48:03 host transmission-daemon[1997]: The Homesman 2014 720p Bluray DTS x264 Worldwide7477 Retrying announce in 7200 seconds. (announcer.c:1004)
Aug 1 03:00:36 host usb: USB /dev/sda2(ntfs) failed to mount At the first try!
Aug 1 03:00:36 host kernel: usb 2-2: new high speed USB device using ehci_hcd and address 2
Aug 1 03:00:36 host usb: USB ntfs fs at /dev/sda2 mounted on /tmp/mnt/HHX.
Aug 1 03:00:38 host kernel: usbcore: registered new interface driver usbserial
Aug 1 03:00:38 host kernel: usbcore: registered new interface driver usbserial_generic
Aug 1 03:00:38 host kernel: usbserial: USB Serial Driver core
Aug 1 03:00:41 host kernel: usb 2-2: GSM modem (1-port) converter now attached to ttyUSB0
Aug 1 03:00:41 host kernel: usb 2-2: GSM modem (1-port) converter now attached to ttyUSB1
Aug 1 03:00:41 host kernel: usb 2-2: GSM modem (1-port) converter now attached to ttyUSB2
Aug 1 03:00:41 host kernel: usbcore: registered new interface driver option
Jul 28 04:04:43 host usb: USB /dev/sda1(ntfs) failed to mount At the first try!
Jul 28 04:04:43 host usb: USB ntfs fs at /dev/sda1 mounted on /tmp/mnt/SYSTEM.
Aug 1 03:00:35 host kernel: usb 2-2: new high speed USB device using ehci_hcd and address 2
Aug 1 03:00:36 host usb: USB /dev/sda1(ntfs) failed to mount At the first try!
Aug 1 03:00:37 host usb: USB ntfs fs at /dev/sda1 mounted on /tmp/mnt/SYSTEM.
Aug 1 03:00:37 host kernel: usbcore: registered new interface driver usbserial
Aug 1 03:00:37 host kernel: usbcore: registered new interface driver usbserial_generic
Aug 1 03:00:37 host kernel: usbserial: USB Serial Driver core
Jul 28 07:43:23 host kernel: usb 2-2: GSM modem (1-port) converter now attached to ttyUSB0
Jul 28 07:43:23 host kernel: usb 2-2: GSM modem (1-port) converter now attached to ttyUSB1
Jul 28 07:43:23 host kernel: usb 2-2: GSM modem (1-port) converter now attached to ttyUSB2
Jul 28 07:43:23 host kernel: usbcore: registered new interface driver option
Jul 28 07:44:38 host usb: USB ext4 fs at /dev/sda3 mounted on /tmp/mnt/DOWNLOADS.
Jul 28 07:45:16 host usb: USB /dev/sda2(ntfs) failed to mount At the first try!
Jul 28 07:45:16 host usb: USB ntfs fs at /dev/sda2 mounted on /tmp/mnt/HHX.
