Syslog
lfbb
Updating RT-N66U to NVRAM 64K... Lets see the results
Update link:
Jan 1 00:00:09 syslogd started: BusyBox v1.17.4
Jan 1 00:00:09 kernel: klogd started: BusyBox v1.17.4 (2012-05-14 08:33:01 CST)
Jan 1 00:00:09 kernel: Linux version 2.6.22.19 (root@asus) (gcc version 4.2.4) #2 Mon May 14 08:42:52 CST 2012
Jan 1 00:00:09 kernel: CPU revision is: 00019749
Jan 1 00:00:09 kernel: Determined physical RAM map:
Jan 1 00:00:09 kernel: memory: 07fff000 @ 00000000 (usable)
Jan 1 00:00:09 kernel: memory: 08000000 @ 87fff000 (usable)
Jan 1 00:00:09 kernel: Zone PFN ranges:
Jan 1 00:00:09 kernel: Normal 0 -> 131072
Jan 1 00:00:09 kernel: HighMem 131072 -> 589823
Jan 1 00:00:09 kernel: early_node_map[2] active PFN ranges
Jan 1 00:00:09 kernel: 0: 0 -> 32767
Jan 1 00:00:09 kernel: 0: 557055 -> 589823
Jan 1 00:00:09 syslog: module ledtrig-usbdev not found in modules.dep
Jan 1 00:00:09 syslog: module leds-usb not found in modules.dep
Jan 1 00:00:09 kernel: Built 1 zonelists. Total pages: 65535
Jan 1 00:00:09 kernel: Kernel command line: root=/dev/mtdblock2 noinitrd console=ttyS0,115200
Jan 1 00:00:09 kernel: Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Jan 1 00:00:09 kernel: Primary data cache 32kB, 4-way, linesize 32 bytes.
Jan 1 00:00:09 kernel: Synthesized TLB refill handler (20 instructions).
Jan 1 00:00:09 kernel: Synthesized TLB load handler fastpath (32 instructions).
Jan 1 00:00:09 kernel: Synthesized TLB store handler fastpath (32 instructions).
Jan 1 00:00:09 kernel: Synthesized TLB modify handler fastpath (31 instructions).
http://forums.smallnetbuilder.com/showthread.php?t=6714&page=78
Jan 1 00:00:06 syslogd started: BusyBox v1.17.4
Jan 1 00:00:06 kernel: klogd started: BusyBox v1.17.4 (2012-10-23 23:11:05 EDT)
Jan 1 00:00:06 kernel: Linux version 2.6.22.19 (root@asus) (gcc version 4.2.4) #1 Tue Oct 23 23:37:39 EDT 2012
Jan 1 00:00:06 kernel: CPU revision is: 00019749
Jan 1 00:00:06 kernel: Determined physical RAM map:
Jan 1 00:00:06 kernel: memory: 07fff000 @ 00000000 (usable)
Jan 1 00:00:06 kernel: memory: 08000000 @ 87fff000 (usable)
Jan 1 00:00:06 kernel: Built 1 zonelists. Total pages: 585216
Jan 1 00:00:06 kernel: Kernel command line: root=/dev/mtdblock2 noinitrd console=ttyS0,115200
Jan 1 00:00:06 kernel: Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Jan 1 00:00:06 kernel: Primary data cache 32kB, 4-way, linesize 32 bytes.
Jan 1 00:00:06 kernel: Synthesized TLB refill handler (20 instructions).
Jan 1 00:00:06 syslog: module ledtrig-usbdev not found in modules.dep
Jan 1 00:00:06 syslog: module leds-usb not found in modules.dep
Jan 1 00:00:06 kernel: Synthesized TLB load handler fastpath (32 instructions).
Jan 1 00:00:06 kernel: Synthesized TLB store handler fastpath (32 instructions).
Jan 1 00:00:06 kernel: Synthesized TLB modify handler fastpath (31 instructions).
The first log is from a SNB user's router and the second is mine. As you can see, the lines in bold don't appear in my log, is this normal?
- lfbb
Come on guys, I'm getting paranoid on this. Just tell me if it's normal! :o
- lfbb
ASUSWRT RT-N66U_3.0.0.4 Wed Oct 24 03:11:07 UTC 2012
admin@RT-N66U:/tmp/home/root# dmesg
On node 0 totalpages: 589823
Normal zone: 1024 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 130048 pages, LIFO batch:31
HighMem zone: 3583 pages used for memmap
HighMem zone: 455168 pages, LIFO batch:31
PID hash table entries: 2048 (order: 11, 8192 bytes)
CPU: BCM5300 rev 1 pkg 0 at 600 MHz
Using 300.000 MHz high precision timer.
console [ttyS0] enabled
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 238736k/131068k available (2440k kernel code, 22456k reserved, 491k data, 192k init, 131072k highmem)
Calibrating delay loop... 299.82 BogoMIPS (lpj=1499136)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
PCI: Initializing host
PCI: Reset RC
PCI: Reset RC
PCI: Fixing up bus 0
PCI/PCIe coreunit 0 is set to bus 1.
PCI: Fixing up bridge
PCI: Setting latency timer of device 0000:01:00.0 to 64
PCI: Setting latency timer of device 0000:01:00.1 to 64
PCI: Enabling device 0000:01:00.1 (0004 -> 0006)
PCI: Fixing up bus 1
PCI/PCIe coreunit 1 is set to bus 2.
PCI: Setting latency timer of device 0000:02:00.0 to 64
PCI: Setting latency timer of device 0000:02:00.1 to 64
PCI: Enabling device 0000:02:00.1 (0004 -> 0006)
PCI: Fixing up bus 2
NET: Registered protocol family 2
Time: MIPS clocksource has been installed.
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
highmem bounce pool size: 64 pages
squashfs: version 3.2-r2 (2007/01/15) Phillip Lougher
io scheduler noop registered (default)
HDLC line discipline: version $Revision: 4.8 $, maxframe=4096
N_HDLC line discipline registered.
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0xb8000300 (irq = 8) is a 16550A
serial8250: ttyS1 at MMIO 0xb8000400 (irq = 8) is a 16550A
PPP generic driver version 2.4.2
MPPE/MPPC encryption/compression module registered
NET: Registered protocol family 24
PPPoL2TP kernel driver, V0.18.3
PPTP driver version 0.8.5
Physically mapped flash: Found 1 x16 devices at 0x0 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
Physically mapped flash: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Flash device: 0x2000000 at 0x1c000000
Creating 5 MTD partitions on "Physically mapped flash":
0x00000000-0x00040000 : "pmon"
0x00040000-0x01fe0000 : "linux"
0x00167e70-0x017c0000 : "rootfs"
0x01fe0000-0x02000000 : "nvram"
0x017c0000-0x01fe0000 : "jffs2"
Found an serial flash with 0 0KB blocks; total size 0MB
sflash: found no supported devices
dev_nvram_init: _nvram_init
_nvram_init: allocat header: 2183725056, size= 65536
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
u32 classifier
OLD policer on
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (2048 buckets, 16384 max)
ipt_time loading
ip_tables: (C) 2000-2006 Netfilter Core Team
net/ipv4/netfilter/tomato_ct.c [Oct 23 2012 23:36:59]
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
All bugs added by David S. Miller <[email protected]>
VFS: Mounted root (squashfs filesystem) readonly.
Freeing unused kernel memory: 192k freed
Warning: unable to open an initial console.
ctf: module license 'Proprietary' taints kernel.
et_module_init: passivemode set to 0x0
PCI: Setting latency timer of device 0000:00:01.0 to 64
eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 5.100.138.20
wl_module_init: passivemode set to 0x0
PCI: Enabling device 0000:01:01.0 (0000 -> 0002)
PCI: Setting latency timer of device 0000:01:01.0 to 64
eth1: Broadcom BCM4331 802.11 Wireless Controller 5.100.138.20
PCI: Enabling device 0000:02:01.0 (0000 -> 0002)
PCI: Setting latency timer of device 0000:02:01.0 to 64
eth2: Broadcom BCM4331 802.11 Wireless Controller 5.100.138.20
Algorithmics/MIPS FPU Emulator v1.5
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
SCSI subsystem initialized
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
ufsd: driver (8.6 U86_r187446_b122, LBD=ON, acl, ioctl, rwm, ws, sd) loaded at c0227000
NTFS (with native replay) support included
optimized: speed
Build_for__asus_n66u_2011-10-27_U86_r187446_b122
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
PCI: Setting latency timer of device 0000:00:04.1 to 64
ehci_hcd 0000:00:04.1: EHCI Host Controller
ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:04.1: EHCI Fastpath: New EHCI driver starting
ehci_hcd 0000:00:04.1: irq 6, io mem 0x18004000
ehci_hcd 0000:00:04.1: USB 0.0 started, EHCI 1.00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
PCI: Setting latency timer of device 0000:00:04.0 to 64
ohci_hcd 0000:00:04.0: OHCI Host Controller
ohci_hcd 0000:00:04.0: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:04.0: irq 6, io mem 0x18009000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usbcore: registered new interface driver usblp
drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
usbcore: registered new interface driver asix
usb 1-1: new high speed USB device using ehci_hcd and address 2
usb 1-1: configuration #1 chosen from 1 choice
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver rndis_host
usbcore: registered new interface driver zaurus
br0: starting userspace STP failed, staring kernel STP
vlan1: add 33:33:00:00:00:01 mcast address to master interface
vlan1: add 01:00:5e:00:00:01 mcast address to master interface
vlan1: dev_set_promiscuity(master, 1)
device eth0 entered promiscuous mode
device vlan1 entered promiscuous mode
usb 1-1.4: new high speed USB device using ehci_hcd and address 3
device eth1 entered promiscuous mode
usb 1-1.4: configuration #1 chosen from 1 choice
scsi0 : SCSI emulation for USB Mass Storage devices
device eth2 entered promiscuous mode
br0: port 3(eth2) entering listening state
br0: port 2(eth1) entering listening state
br0: port 1(vlan1) entering listening state
br0: port 3(eth2) entering learning state
br0: port 2(eth1) entering learning state
br0: port 1(vlan1) entering learning state
br0: topology change detected, propagating
br0: port 3(eth2) entering forwarding state
br0: port 2(eth1) entering forwarding state
br0: port 1(vlan1) entering forwarding state
vlan1: del 01:00:5e:00:00:01 mcast address from vlan interface
vlan1: del 01:00:5e:00:00:01 mcast address from master interface
vlan1: del 33:33:00:00:00:01 mcast address from vlan interface
vlan1: del 33:33:00:00:00:01 mcast address from master interface
br0: port 1(vlan1) entering disabled state
nf_conntrack_rtsp v0.6.21 loading
nf_nat_rtsp v0.6.21 loading
scsi 0:0:0:0: Direct-Access Multi Flash Reader 1.00 PQ: 0 ANSI: 0
sd 0:0:0:0: [sda] Attached SCSI removable disk
sd 0:0:0:0: Attached scsi generic sg0 type 0
This is all very low-level kernel stuff that happens before the firmware itself gets run. Only a Linux kernel engineer would be able to tell you exactly what each of these entries mean. They are usually merely information as to what is happening, meant for debugging. I wouldn't worry about any of it.
The two logs appear to be from different fimrware versions. I wouldn't expect them to match..
