Hi there,
I wonder if you can help me with the following error I see under system log.
kernel: EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: xxx
kernel: EXT2-fs (sda1): error: remounting filesystem read-only
This appears literally every second in the logs one after another. I have an Asus AC68U router which is currently using firmware version 384.17. I'm not sure if this error is in anyway related but I've also noticed that skynet stats under the WebUI is no longer updating past the 8th July. Also the UIdivStats is blank. Again, not sure if any relation to the error.
Would appreciate any assistance with this issue.
Many thanks.
Many thanks.
