System logs: already exist in UDB, can't add it
peter
In system logs I can see this repeating message. What does it mean and How can I remove it? I do not know that my device has this IP.
Jan 9 23:17:15 kernel: 192.168.1.221 already exist in UDB, can't add it
Jan 9 23:17:15 kernel: 192.168.1.235 already exist in UDB, can't add it
Jan 9 23:18:29 kernel: 192.168.1.221 already exist in UDB, can't add it
Jan 9 23:18:29 kernel: 192.168.1.235 already exist in UDB, can't add it
Same here. I think it started after upgrading to 386.4 :-(
Not yet ready to do a factory reset and rebuild from scratch ...
Do you use AiMesh? One of my networks is AiMesh of a few Asus routers and access points and when AiMesh is on I see the exact same log entries while as soon as I disable AiMesh those are gone.
Appears, and I am speculating here because I am not 100%sure, that the built-into kernel UDB db thinks that IP address is already given out to a device while it is very possible it is not. Why do I say possibly it is not? Well, I found when searching that none of my devices had the IP address log showed/reported, but it appears as a bug in the kernel code that there is not a complete sync between meshed devices and one of the nodes thinks that the IP is already given as it likely was in the past to a device and that the device with the specific IP is still present on the net but UDB for to me unknown reasons remembered it and keeps a hold of it. Also noticed, if I reboot all meshed devices the system log then shows another IP address....very confusing and so far I have not found any useful explanation by anyone, not Asus forums of any kind nor Asuswrt-merlin development community or users. :(
