Tcp time out established
Raiu
I just noticed this in the 42-2 Merlin build
TCP Timeout: Established 43200 Default: 1200
I have never played with that nor understand what that value is for should I change it back to 1200?
I am running open vpn did that change it?
Kernel 2.6.22 (MIPS routers) and 2.6.36 (ARM) have different default values. The webpage simply does not check which router it's based on, so it mentions the MIPS default value. 432000 is the correct default value for ARM routers running the 2.6.36 kernel.
Ah, thanks!
