Tcpdump shows vpn dns queries
Goobi
Hi community,
I got PIA vpn configured on my 86u router with policy rules. The VPN DNS gets pushed down to the clients and dnsleaktest on them show the VPN DNS. However, I was testing out DoT and running tcpdump to see if I see any traffic on port 53. Aside for a few time lookups from the router itself, I see all the queries from my VPN DNS. Is this normal? Is this considered a DNS leak?
Thanks in advance
Hi community,
Thanks in advance
This sounds like not a DNS leak, since tcpdump is picking up the query before it enters the tunnel.
Without knowing more about your setup, that's my initial hunch.
[edit]
To confirm that hunch, I'd follow along these kind of steps:
  • Assuming TCPDump is on the router itself, and testing is done from wifi/wired clients
  • Visit a new and unique domain name from the client (e.g., www.ihavenotvsitiedthissitebefore.net)
  • Watch all the TCPDump log for that domain
  • You should notice that the router received a query on the LAN for that domain
  • You should also notice that the router did not send a query on the WAN for that domain.
  • If all of the above are true... it should be indicative of no DNS leak.
Thanks, tcpdump is on the router and I will continue to monitor using the above as a guide.
