Telco f/w Locked RBK50
  • ATTENTION! As of November 1, 2020, you will not be able to reply to threads 6 months after the thread is opened. Threads will not be locked, so posts may still be edited by their authors.
zahi_k
I own an RBK50 system with F/W 2.1.4.16_1.1.31
my product is being sold by a Telco Provider. hence, it have a custom OLD firmware with a security lock that is preventing the upgrade unless it is signed by my Telco.
Netgear won't be able to support; My Telco as well.
is there an alternate way or backdoor to drop the latest f/w.
avtella
He many need to use the burn board id command, if the ISP changed the board ID otherwise it won’t work even with a tftp flash. I’m hoping you don’t need to go that route.
e38BimmerFN
zahi_k
none of the TFT method works... there is no orange LED. it immediately switch to green. even when i reset, it goes from stable green to stable red to 3 seconds of flashing red and then green. it won't accept TFTP using the app or windows....
does this help ??
Board HW ID : 29765352+0+4000+512+2x2+2x2+4x4
Board Model ID : RBR50
Board Data : 1101
zahi_k
Tried all possible method on netgear support page.... any custom f/w i could use? or my isp will even block it?
