AC88 using 384.10 beta 2 (same behavior noted on 384.8 and 384.9) with:
amtm
diversion
dnscrypt
using dnsfilter with quad9.
Router crashes on a 4 to 5 day basis. I think is is a dnscrypt problem, although miniupnpd raises it's head once in a while). There is a plex server online, but it's only involved in one instance. Here are excerpts from the logs leading up to a crash:
Mar 22 05:15:31 dnsmasq[15075]: possible DNS-rebind attack detected: 192-168-1-95.abcdefghijklmnopqrstuvwxyz012345.plex.direct
Mar 22 05:16:39 asusRouter: Warning: dnscrypt-proxy is not responding
Mar 22 05:16:40 asusRouter: Start dnscrypt-proxy
Mar 22 05:16:41 dnscrypt-proxy[207]: Stopped.
Mar 22 05:16:44 dnscrypt-proxy[30631]: dnscrypt-proxy 2.0.19
Mar 22 05:16:44 dnscrypt-proxy[30631]: Dropping privileges
Mar 22 05:16:44 dnscrypt-proxy[30631]: Source [public-resolvers.md] loaded
Mar 22 05:16:44 dnscrypt-proxy[30631]: Now listening to 127.0.0.1:65053 [UDP]
Mar 22 05:16:44 dnscrypt-proxy[30631]: Now listening to 127.0.0.1:65053 [TCP]
Mar 22 05:16:45 dnscrypt-proxy[30631]: [quad9-dnscrypt-ip4-filter-pri] OK (crypto v1) - rtt: 56ms
Mar 22 05:16:45 dnscrypt-proxy[30631]: [quad9-dnscrypt-ip4-filter-alt] OK (crypto v1) - rtt: 18ms
Mar 22 05:16:45 dnscrypt-proxy[30631]: Server with the lowest initial latency: quad9-dnscrypt-ip4-filter-alt (rtt: 18ms)
Mar 22 05:16:45 dnscrypt-proxy[30631]: dnscrypt-proxy is ready - live servers: 2
Mar 22 06:06:47 miniupnpd[800]: send(res_buf): Connection reset by peer
Mar 22 06:07:00 asusRouter: Warning: dnscrypt-proxy is not responding
Mar 22 06:07:00 asusRouter: Start dnscrypt-proxy
Mar 22 06:07:02 dnscrypt-proxy[1147]: Stopped.
Mar 22 06:07:04 dnscrypt-proxy[2078]: dnscrypt-proxy 2.0.19
Mar 22 06:07:04 dnscrypt-proxy[2078]: Dropping privileges
Mar 22 06:07:05 dnscrypt-proxy[2078]: Source [public-resolvers.md] loaded
Mar 22 06:07:05 dnscrypt-proxy[2078]: dnscrypt-proxy 2.0.19
Mar 22 06:07:05 dnscrypt-proxy[2078]: Now listening to 127.0.0.1:65053 [UDP]
Mar 22 06:07:05 dnscrypt-proxy[2078]: Now listening to 127.0.0.1:65053 [TCP]
Mar 22 06:07:06 dnscrypt-proxy[2078]: [quad9-dnscrypt-ip4-filter-pri] OK (crypto v1) - rtt: 216ms
Mar 22 06:07:06 dnscrypt-proxy[2078]: [quad9-dnscrypt-ip4-filter-alt] OK (crypto v1) - rtt: 19ms
Mar 22 06:07:06 dnscrypt-proxy[2078]: Server with the lowest initial latency: quad9-dnscrypt-ip4-filter-alt (rtt: 19ms)
Mar 22 06:07:06 dnscrypt-proxy[2078]: dnscrypt-proxy is ready - live servers: 2
Mar 22 06:08:23 asusRouter: Warning: dnscrypt-proxy is not responding
Mar 22 06:08:25 asusRouter: Start dnscrypt-proxy
Mar 22 06:08:29 dnscrypt-proxy[2136]: dnscrypt-proxy 2.0.19
Mar 22 06:08:30 dnscrypt-proxy[2136]: listen udp 127.0.0.1:65053: bind: address already in use
Mar 22 06:08:56 nat: apply redirect rules
Mar 22 06:08:59 WAN_Connection: ISP's DHCP did not function properly.
Mar 22 06:09:08 DualWAN: skip single wan wan_led_control - WANRED off
Mar 22 06:09:29 asusRouter: Warning: dnscrypt-proxy is dead
Mar 22 06:09:29 asusRouter: Start dnscrypt-proxy
Mar 22 06:09:34 dnscrypt-proxy[2397]: Source [public-resolvers.md] loaded
Mar 22 06:09:34 dnscrypt-proxy[2397]: dnscrypt-proxy 2.0.19
Mar 22 06:09:34 dnscrypt-proxy[2397]: Dropping privileges
Mar 22 06:09:37 dnscrypt-proxy[2397]: dnscrypt-proxy 2.0.19
Mar 22 06:09:38 dnscrypt-proxy[2397]: Now listening to 127.0.0.1:65053 [UDP]
Mar 22 06:09:38 dnscrypt-proxy[2397]: Now listening to 127.0.0.1:65053 [TCP]
Mar 22 06:09:38 dnscrypt-proxy[2397]: [quad9-dnscrypt-ip4-filter-pri] OK (crypto v1) - rtt: 105ms
Mar 22 06:09:38 dnscrypt-proxy[2397]: [quad9-dnscrypt-ip4-filter-alt] OK (crypto v1) - rtt: 18ms
Mar 22 06:09:38 dnscrypt-proxy[2397]: Server with the lowest initial latency: quad9-dnscrypt-ip4-filter-alt (rtt: 18ms)
Mar 22 06:09:38 dnscrypt-proxy[2397]: dnscrypt-proxy is ready - live servers: 2
Mar 22 06:10:25 asusRouter: Warning: dnscrypt-proxy is not responding
Mar 22 06:10:26 asusRouter: Start dnscrypt-proxy
Mar 22 06:10:45 dnscrypt-proxy[2440]: Source [public-resolvers.md] loaded
Mar 22 06:10:45 dnscrypt-proxy[2440]: dnscrypt-proxy 2.0.19
Mar 22 06:10:45 dnscrypt-proxy[2440]: listen udp 127.0.0.1:65053: bind: address already in use
Mar 22 06:11:57 dnscrypt-proxy[2397]: Stopped.
Mar 22 06:13:46 kernel: tdts_core_ioctl_udb_op_prog_ctrl() fail!
Mar 22 06:14:35 dnsmasq-dhcp[15075]: DHCPDISCOVER(br0) 58:c3:8b:67:75:9c
Mar 22 06:14:35 dnsmasq-dhcp[15075]: DHCPOFFER(br0) 192.168.1.134 58:c3:8b:67:75:9c
Mar 22 06:14:38 asusRouter: Warning: dnscrypt-proxy is dead
Mar 22 06:14:38 asusRouter: Start dnscrypt-proxy
Mar 22 06:14:43 dnscrypt-proxy[2490]: dnscrypt-proxy 2.0.19
Mar 22 06:14:43 dnscrypt-proxy[2490]: Dropping privileges
Mar 22 06:14:45 dnscrypt-proxy[2490]: dnscrypt-proxy 2.0.19
Mar 22 06:14:45 dnscrypt-proxy[2490]: Now listening to 127.0.0.1:65053 [UDP]
Mar 22 06:14:45 dnscrypt-proxy[2490]: Now listening to 127.0.0.1:65053 [TCP]
Mar 22 06:14:45 dnscrypt-proxy[2490]: [quad9-dnscrypt-ip4-filter-pri] OK (crypto v1) - rtt: 103ms
Mar 22 06:14:45 dnscrypt-proxy[2490]: [quad9-dnscrypt-ip4-filter-alt] OK (crypto v1) - rtt: 19ms
Mar 22 06:14:45 dnscrypt-proxy[2490]: Server with the lowest initial latency: quad9-dnscrypt-ip4-filter-alt (rtt: 19ms)
Mar 22 06:14:45 dnscrypt-proxy[2490]: dnscrypt-proxy is ready - live servers: 2
Mar 22 06:16:25 asusRouter: Warning: dnscrypt-proxy is not responding
Mar 22 06:16:25 asusRouter: Start dnscrypt-proxy
Mar 22 06:16:27 dnscrypt-proxy[2490]: Stopped.
Mar 22 06:30:29 nat: apply redirect rules error!
Mar 22 06:30:33 WAN_Connection: ISP's DHCP did not function properly.
Mar 22 06:30:28 dnsmasq-dhcp[15075]: DHCPREQUEST(br0) 192.168.1.134 58:c3:8b:67:75:9c
Mar 22 06:30:42 dnsmasq-dhcp[15075]: DHCPACK(br0) 192.168.1.134 58:c3:8b:67:75:9c android-b53b40ae44727e11
Mar 22 06:30:43 dnsmasq-dhcp[15075]: DHCPDISCOVER(br0) 58:c3:8b:67:75:9c
Mar 22 06:30:43 dnsmasq-dhcp[15075]: DHCPOFFER(br0) 192.168.1.134 58:c3:8b:67:75:9c
Mar 22 06:31:34 DualWAN: skip single wan wan_led_control - WANRED off
Mar 22 06:31:43 nat: apply redirect rules
Mar 22 06:32:54 WAN_Connection: WAN was restored.
Mar 22 06:48:04 asusRouter: Warning: dnscrypt-proxy is not responding
Mar 22 05:44:24 syslogd started: BusyBox v1.25.1
Mar 22 05:44:24 kernel: klogd started: BusyBox v1.25.1 (2019-03-17 13:07:21 EDT)
Mar 22 05:44:24 kernel: Linux version 2.6.36.4brcmarm (merlin@ubuntu-dev) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 SMP PREEMPT Sun Mar 17 13:17:11 EDT 2019
Mar 22 05:44:24 kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
Mar 22 05:44:24 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
amtm
diversion
dnscrypt
