Time scheduling - anyone else having problems?
smallnetbuildpaul
I made a mess of my router yesterday and had to factory reset.
Spent today reconfiguring and seem to have problems with parental controls.
There seemed to be a correlation between enabling the "time scheduling" element of Parental Controls and sporadic loss of connectivity on our Xbox One. With the time scheduling switched off, the Xbox was stable. With it switched on the Xbox kept losing connectivity.
Is this a known issue?
I'm on 384.9 and, strangely this was all working fine before I had to do the factory reset.
Thanks in advance
Did you try rebooting the router and seeing if that fixed it?
Thanks L&LD. Just to follow up the router has once again been solid as a rock ever since and no further problems with the xbox. Must have been a coincidence only.
