Tinc VPN Support
wiak
Tinc is a different take on VPN compared to OpenVPN.
Its also open source, runs on basicly anything. its small, light and quite fast
http://www.tinc-vpn.org/
What is tinc?
tinc is a Virtual Private Network (VPN) daemon that uses tunnelling and encryption to create a secure private network between hosts on the Internet. tinc is Free Software and licensed under the GNU General Public License version 2 or later. Because the VPN appears to the IP level network code as a normal network device, there is no need to adapt any existing software. This allows VPN sites to share information with each other over the Internet without exposing any information to others. In addition, tinc has the following features:
Encryption, authentication and compression
All traffic is optionally compressed using zlib or LZO, and OpenSSL is used to encrypt the traffic and protect it from alteration with message authentication codes and sequence numbers.
Automatic full mesh routing
Regardless of how you set up the tinc daemons to connect to each other, VPN traffic is always (if possible) sent directly to the destination, without going through intermediate hops.
Easily expand your VPN
When you want to add nodes to your VPN, all you have to do is add an extra configuration file, there is no need to start new daemons or create and configure new devices or network interfaces.
Ability to bridge ethernet segments
You can link multiple ethernet segments together to work like a single segment, allowing you to run applications and games that normally only work on a LAN over the Internet.
Runs on many operating systems and supports IPv6
Currently Linux, FreeBSD, OpenBSD, NetBSD, MacOS/X, Solaris, Windows 2000, XP, Vista and Windows 7 and 8 platforms are supported. See our section about supported platforms for more information about the state of the ports. tinc has also full support for IPv6, providing both the possibility of tunneling IPv6 traffic over its tunnels and of creating tunnels over existing IPv6 networks.
I know of some Asuswrt users running tinc using some binaries I make of the latest tinc1.1 branch.
http://files.lancethepants.com/Binaries/tinc/
They talk a little bit about it here.
http://www.linksysinfo.org/index.php?threads/tinc-mesh-vpn.70257/
i made a guide the other day here
http://nwgat.ninja/tinc-vpn-on-asuswrt-merlin/
currently it will act as a switch, so no bridging of lan, i need to find out how to do that in merlin firmware
*correction still working on it, will repost it later, now with simpler instructions :)
