TLS error with OpenVPN client
GSpock
Hi all,
I just noticed some TLS errors in syslog file related to my openvpn client 2 ; there is only one device linked to this openvpn client and this a synology NAS. My other openvpn client do not report such errors ...
any ideas ?
Thx,
GS
Jul  5 18:04:35 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=26
Jul  5 18:24:20 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=17
Jul  5 18:27:55 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=1
Jul  5 18:46:12 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=14
Jul  5 19:51:05 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=24
Jul  5 20:09:57 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=30
Jul  5 21:02:42 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=15
Jul  5 21:12:20 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=21
Jul  6 00:33:01 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=14
Jul  6 03:38:16 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=23
Jul  6 03:38:57 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=24
Jul  6 03:58:28 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=22
Jul  6 04:00:51 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=17
Jul  6 04:01:20 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=13
Jul  6 04:02:45 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=20
Jul  6 04:05:45 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=20
Jul  6 04:19:14 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=25
Jul  6 04:23:03 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=23
Jul  6 04:24:29 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=25
Jul  6 04:26:21 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=27
Jul  6 04:26:51 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=13
Jul  6 04:28:46 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=15
Jul  6 04:33:10 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=16
Jul  6 04:34:38 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=18
Jul  6 04:35:34 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=17
Jul  6 04:39:26 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=17
Jul  6 04:40:26 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=23
Jul  6 04:42:50 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=31
Jul  6 04:46:35 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=27
Jul  6 04:47:18 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=29
Jul  6 04:49:39 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=27
Jul  6 04:51:48 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=15
Jul  6 05:04:55 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=19
Jul  6 05:31:05 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=30
Jul  6 07:04:47 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=17
Jul  6 07:24:29 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=28
Jul  6 07:26:55 ovpn-client2[9820]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxx op=0
Additional errors ...
Jul  6 10:02:41 ovpn-client2[20541]: Authenticate/Decrypt packet error: packet HMAC authentication failed
Jul  6 10:02:41 ovpn-client2[20541]: TLS Error: incoming packet authentication failed from [AF_INET]185.xxx.xxx.xxx:xxxx
Jul  6 10:08:23 ovpn-client2[20541]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxxx op=24
Jul  6 10:10:02 ovpn-client2[20541]: TLS Error: Unroutable control packet received from [AF_INET]185.xxx.xxx.xxx:xxxx (si=3 op=P_CONTROL_SOFT_RESET_V1)
Jul  6 10:16:34 ovpn-client2[20541]: TLS Error: Unroutable control packet received from [AF_INET]185.xxx.xxx.xxx:xxxx (si=3 op=P_ACK_V1)
Jul  6 10:18:57 ovpn-client2[20541]: Peer tried unsupported key-method 1
Jul  6 10:18:57 ovpn-client2[20541]: TLS Error: unknown opcode received from [AF_INET]185.xxx.xxx.xxx:xxxx op=2
Is the OpenVPN client working despite these errors? Do you have the Inbound Firwall option set to Block (the default)? Who is the VPN provider (in case they are known to produce such errors)?
Yes
Yes
Torguard ; but I have 3 other vpnclient with them and only #2 is causing those error messages ....
Not sure what the problem is, but perhaps it's just a misconfiguration w/ that specific server.
