Some more indepth details here for those interested
https://fccid.io/YJ7DCT100
This is for the Stanley Black & Decker branded version though, but it's pretty clear it's the same hardware.
It's easily one of the weirdest Wi-Fi access points I've ever seen.
It's got a Freescale SoC which I can't really identify, but I'd hazard a guess that it's an i.MX 6 as there's a PLX PCIe bridge that split one PCIe lane into two for the Wi-Fi cards. That said, only the i.MX 6 SoloX has two Gigabit Ethernet ports and PCIe in the range, so it's the only possible option if it's indeed an i.MX 6 SoC.
Both Wi-Fi modules are Atheros based.
The 2.4GHz radio uses the AR9283 chipset and it's this exact module -
https://www.compex.com.sg/product/wle200n2-23/
The 5GHz radio uses the AR9280 chipset and it's this exact module -
https://www.compex.com.sg/product/wle200n5-23/
In other words, a late 2017 device using chipsets announced in 2009 and 2008 respectively and no 802.11ac support.
The weirdest thing is the power supply, which is an encapsulated power supply from Mean Well
https://www.meanwell-web.com/en-gb/ac-dc-single-output-encapsulated-power-supply-irm--20--24
It's really rather expensive for what it is, costing $6.50 in quantities of 1k.
There's no wonder that this device is $1,495 when it appears to be made by someone that doesn't have the first clue about routers or how to make electronics. It should be possible to do something a lot more affordable and most likely reliable, simply using actual router hardware than this mish mash of bits.
