Tor as a proxy by port in the LAN
Steklorez
Hi.
Tor as a proxy by port in the LAN.
Is it possible to somehow use the option Tor as a proxy server?
It is necessary that the traffic went through Tor only for the specified port. For example a browser or other applications that can be configured on the proxy server IP: PORT (192.168.1.1:хххх).
Perenapravlyaet all incandescent traffic network does not need me.
It is ill advised to make a transparent proxy for TOR. TOR has a lot of security breaches that if you want TOR you first need to find 3 nodes that are far apart from each other (such as 1 in china, 1 in russia, 1 in US as an example), You can create the connection/proxy on your router but have your clients manually configure it. You need to carefully make sure that only the traffic you want passes through TOR network because you do not want to start leaking things about. One of the advise given is to not have an internet connection on the PC while using TOR and make sure that all other network applications do not run.
It has been discussed that TOR is very vulnerable and doesnt protect against websites that can obtain your actual information via web scripts and pdf files that when open can communicate with an external server. Even the nodes if all 3 of them are owned by the same person could than be used to figure you out. Using a normal web proxy with encryption is more secure than TOR. SSTP or openVPN are also much more secure than TOR.
