pege63
Does any one have this TP-Link EAP330 AP at home?
- 1900Mbps wireless data rate for uninterrupted wireless connection
- Airtime Fairness, Beamforming and Band Steering technology provide optimal RF performance for best Wi-Fi experience in High-Density environment
- Link aggregation between two Gigabit Ethernet ports breaks the bottleneck in network backhaul capacity
- Free Controller Software for easy centralized management of hundreds of EAPs
- Power over Ethernet(802.3at)Support for convenient and affordable installation
- Captive portal provides one convenient method of authentication for WiFi guests
- Simple mounting design makes easy to install on any wall or ceiling surface
- Rate limit on per SSID to restrict the bandwidth of each client
- Load balance ensures large numbers of users have smooth network experiences in high density business networks
- Access Control restricts or only allows the client to access the specified network segment
- Reboot Schedule enables all the APs to reboot automatically at a specified time
- WPA/WPA2-enterprise, 802.1X with RADIUS secure authentication and rogue access point detection ensure the security of WLAN
- Multi-SSID divides multiple wireless network for different users
- Compatible with 802.11 a/b/g/n/ac products
- Adopts Low Smoke Zero Halogen (LSOH) materials for UL2043 compliance
- Multiple operating modes satisfy different application conditions including managed AP and standalone AP modes
- Qos function gives video and voice streams higher priority to promote smoother performance for video and voice services
- Speeds of up to 1.9Gbps over concurrent dual band 802.11ac Wi-Fi with MIMO and TurboQAM technologies
- Airtime Fairness, Beamforming, and Band Steering Technologies guarantee optimal RF performance for business-level applications
- Link aggregation joins two gigabit Ethernet ports to break the bottleneck in network backhaul capacity
- Free EAP Controller Software lets administrators easily manage hundreds of EAPs
- Captive portal provides a convenient method for guest authentication
- Power over Ethernet (802.3at) support and simple mounting design allow for flexible deployment and convenient installation
