tp link r480t+ DUAL WAN router INIT SETUP
cafeine
Hello to all, new member here and looking for instructions on how to setup my tp link r480t+.
My hardware is:
2 adsl modem-routers given from the ISPs
1 switch
2 computers
1 QNAP TS110 NAS
and the tp link r480t+
I tried connecting the computers and NAS to the switch...ok...everything can see each other.
I connected the switch to the LAN port on the tp link r480t+.
I connected the 2 adsl modem/routers (no bridging option though...) to the WAN ports of the tp link r480t+
What setttings must I do in order to be able to share both connections to all LAN pcs and NAS?
I tried the instructions TP LINK has but at no use....
Anyone can help? appreciated...
In case someone is having same problems here is what i did and made it work after all....
- put both modems in bridge mode, disable all settings (NAT, firewalls, port forwarding, DHCP! etc). Write down the MAC address of each modem.
- connect them to the wan gates
- in each pc/laptop you connect to the LAN ports, make sure you give it a static IP and set the gateway to the ip of the TP LINK plus primary DNS the same as gateway.
- if you wanna have wifi, then connect a wifi router to one of the LAN ports in TP LINK, and assign it a static IP.
In DHCP settings in TP LINK, set the address reservations for all devices according to their MAC Address.
this should get everyone started...more in time!
have fun...
D Which route should i go? TP LINK Omada ER707-M2 vs Asus GT BE98 Routers 0
