Traffic Analyzer - Statistic only goes back 15 days
ronmis
I have the RT-AX3000 with the latest Asus Merlin installed on it, It has been running for several months. The only issue I seem to have with it is that the Traffic Analyzer - Statistic provides data for only the last 15 days.
Anyone know why this is happening and if there is a way to correct it?
Under Tools - Other Settings, the Traffic history location is set to RAM (Default). I don't have any Addons/scripts installed, so I don't think space is an issue.
Unrelated to Traffic Analyzer, used for Traffic Monitor only. Traffic Analyzer stores data in jffs and the file size is limited.
Gotcha. My JFFS currently shows 7.32 / 47.00 MB. So something else is probably going on.
I found this Traffic Analyzer rather buggy. I never had it running longer than a week before it just stops recording.
Did you upgrade from an older version of Merlin 15 days ago. A couple of versions ago my entire traffic analyzer history (about 4 years) was wiped out during an upgrade.
I upgraded to the latest version a couple of weeks back, but this has been happening from the time I got this router, in Jan this year.
