Traffic Monitor - Daily Graph Issue
bluzfanmr1
I searched but couldn't find an answer to this. On Dec 15 the daily graph (see below) under the traffic monitor tab is showing a gigantic amount of data was transmitted. The monthly totals look normal. And actually as I type this right now today's data is showing another huge data spike.
I don't believe the data spike is accurate and there's some kind of glitch. Maybe my usb stick is going bad? Any other ideas? Can I fix this in some way without losing the data?
I forgot to add that the daily totals were showing up fine before that huge spike in Dec 15th.
I'm seeing the same thing. AC68U after dirty flash from 384.13 to 384.14.
And before anyone asks - no, I don't have hw acceleration enabled... or if it is, it's not something that can be disabled because the GUI already says (under Tools/Sysinfo/Network/HW acceleration) "Disabled (by user)"
I also clobbered my stats (Tools/Other settings/Create or reset data files) so that any corruption there wouldn't be the cause, and that didn't help either - the problem came back again.
