Traffic Monitor - Saving to USB
GhostX
Hello,
I just installed Asuswrt-Merlin 378.55 on my ASUS RT-N66U Router and configured the traffic monitoring to be saved to my USB Flash Drive (/mnt/sdb1/), but every few days, I check and the data is all gone.
Am I doing something wrong? I just checked this morning and the last 3 days of data is no longer available when I go under the traffic monitoring option.
Thanks,
I use same firmware version 378.55 and same router RT-N66U and I have the same issue you have. There is tomato_rstats_382c4aced6c8.gz file on my USB flash drive, but my Daily traffic history tells "No data in table."
right now I have disabled NAT acceleration, maybe it will help
I got it working. Try to restore traffic stats back to RAM (default), reboot.
After reboot choose Custom location for traffic stats, Create or reset data files: YES
Apply, and reboot once more.
check your Traffic Manager - Traffic Monitor
