Traffic Monitoring
Crawl71
Good Morning,
First off thought I would just say that this is a fantastic project and I'm very glad that I stumbled upon it. I do have a question though and after reading a lot of posts thought I would post this.
I am trying to setup Traffic Monitoring and seem to be having a bit of an issue getting the router to save the history to my USB.
Here is what I have done.
Selected 'Custom Location'
Save history location - '/mnt/'
Create or Reset data files - 'Yes'
Enable IPTraffic - 'Yes'
Create or Reset IPTraffic - 'Yes'
Monitor all IP's - 'Yes'
When I press the 'Apply' button, it does its thing but then the 'Create or Reset' fields revert back to 'no'. Also, when I try this and go back to the log, it is giving me an error saying that it can't access the USB. Are the two related and how to I correct this issue?
I am running the following;
Asus RT-N66U - 374.43
Thanks in advance for any help with this and of course sorry if I have left out any important details!
This is the location where all disks are mounted. You have to select a disk inside /mnt/ (for example, /mnt/sda1/ would be the first USB disk).
This is normal, since it only needs to create/erase the database once. You don't want it to happen on every service restart or reboot.
