Traffic Monitoring
Inverse
I used to be able to view the traffic monitoring from within the UI but now I cannot find it.
I found the page that enables me to configure it but I cannot find the page with the traffic statistics.
From the main ASUS GUI select "Traffic Analyzer" then go to the "Traffic Monitor" tab.
Wrong thread and section.
You are running vortex on a Netgear R7000. Probably that feature is not supported on that porting of Asus wrt.
Best to ask to developer directly.
Thanks for the heads up! Going directly to the support forum for R7000 was the right thing. I had to enable some feature and viola all the settings became active :)
Can you post here or direct me to the solution to this? I'm having the same issue but wasn't able to find a solution yet.
