1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. SNBForums Code of Conduct
    Dismiss Notice
Dismiss Notice
Welcome To SNBForums
Traffic monitoring
Discussion in 'ASUS Wireless' started by admiral2145, Nov 9, 2018.
  1. admiral2145
    admiral2145 Regular Contributor
    Jan 1, 2013
    152
    Running a ac68u disabled ctf and all traffic shows up... With it enabled doesn't work.. I have a 500/50 connection with ctf disabled only 250-300mbit...is there a work around to get both cpu cores to work vs only 1 and maxing out and only being 250-300 mbit only on 1 core vs both working together? On newer routers like the 88u or 86u do they have better performance and or able to use ctf and traffic monitoring or is this a bug with all asus routers?
    Sent from my PH-1 using Tapatalk
  2. ColinTaylor
    ColinTaylor Part of the Furniture
    Mar 31, 2014
    10,582
    UK
    It's a known limitation that's always been there. CTF bypasses the normal network code which is why Traffic Monitor doesn't see it. Most of the relevant network code is single threaded so having multiple processors doesn't help, other than a proportional increase based on CPU speed.
    AFAIK the Traffic Monitor is not present on the 86U because it is obsolete code that isn't compatible with the newer kernel.
    Some of the information that Traffic Monitor had is available in the Traffic Analyser which should work even with CTF.
    admiral2145 likes this.
  3. OzarkEdge
    OzarkEdge Very Senior Member
    Feb 14, 2018
    1,915
    USA
    The Traffic Analyzer functionality in this ASUS AC5300 demo appears to match the Traffic Analyzer functionality in my 86U.
    OE
  4. admiral2145
    Jan 1, 2013
    152
    and you have ctf enabled? I might upgrade to a 86u or 88u...
  5. OzarkEdge
    Feb 14, 2018
    1,915
    USA
    If ctf is 'cut through forwarding' or NAT acceleration, then I don't know... I think the 86U removed the setting for NAT acceleration.
    OE
