1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
Transmission rates
Discussion in 'Asuswrt-Merlin' started by EventPhotoMan, Dec 18, 2018.
  1. EventPhotoMan
    EventPhotoMan Senior Member
    Mar 29, 2018
    301
    I see a difference here in my bridge 192.168.1.15, which in connected to an access point 192.168.1.11
    Why the difference in transmission rates?
    9C30DB16-2BF2-4A2E-80DC-B69580C95900.jpeg D3C5B8F3-628E-4ECD-B191-E9C2F9A1FDB3.jpeg
  2. EventPhotoMan
    Mar 29, 2018
    301
  3. Hawk
    Hawk Senior Member
    Mar 9, 2014
    230
    Toronto, Ontario, Canada
    Regarding first screenshot, look like it is either faulty or in power save mode which reduce link rate when idle.
  4. ColinTaylor
    ColinTaylor Part of the Furniture
    Mar 31, 2014
    7,252
    UK
    The rates in the left picture will fluctuate depending on what traffic is currently being transferred at that moment in time. I don't know about the rate on the right as I don't use that setup. But if it never changes I'd speculate that it is showing you the maximum possible rate rather than the current rate.
  5. sfx2000
    sfx2000 Part of the Furniture
    Aug 11, 2011
    13,703
    San Diego, CA
    11n can have asymmetric transmit rates - so looking on one side, you see the AP, the other is the rate from the client.
    It's not unusual...
  6. EventPhotoMan
    Mar 29, 2018
    301
    CA462AF6-740E-433D-BA81-5326983DE85C.jpeg 8641A9EA-AC1D-4B8F-9A45-5994DEF88935.jpeg im not going to explain my whole network, keep my issue simple.
    Hope to clear up some bridge mode issues.
    192.168.1.15 is in bridge mode
    192.168.1.11 is an access point mode
    So the connection rates should be identical?
    Also, access point 192.168.1.11 know the connected client is 192.168.1.15; why does the client 192.168.1.15 not know it’s connected to 192.168.11?
    Just trying to iron out a few things and see if it leads to any solutions.
    My Brydges are not stable.
  7. Jack Yaz
    Jack Yaz Very Senior Member
    Apr 20, 2017
    1,357
  8. EventPhotoMan
    Mar 29, 2018
    301
    Trying to tackle the issue systematically.
    I’m tired of the brydge going down.
    Jack Yaz likes this.
  9. EventPhotoMan
    Mar 29, 2018
    301
    My other brydge when down, 192.168.1.17 (connected to 192.168.1.16)
    How could the wireless be disabled?
  10. EventPhotoMan
    Mar 29, 2018
    301
    And @ColinTaylor suggetion I’d the bit rate changing based on the demand, well, that is not so. I connected a client on 192.168.1.16 and started streaming video.
    The RX/TX rates don’t change.
    Displaying low level details shows the same.
  11. EventPhotoMan
    Mar 29, 2018
    301
    Second brydge , 192.168.1.17, shows the same RX/TX values too of 6 mbps
  12. EventPhotoMan
    Mar 29, 2018
    301
    I’m trying to watch the log file to see if I can get an on-site.
  13. EventPhotoMan
    Mar 29, 2018
    301
    Does anyone know what 'Deep Green mode' is?
    Is there a way to disable this feature?
    I'm thinking my bridges go into sleep mode and loose their connection.
  14. EventPhotoMan
    Mar 29, 2018
    301
    Almost 24 hours and it’s still working
    Thou my confidence is low.
  15. EventPhotoMan
    Mar 29, 2018
    301
    So I came home today.
    192.168.1.17 I could not ping
    But after pinging 192.168.1.15
    It seem to wake up 192.168.1.15, which is connected to .16 and .17
    So my thought are still thinking that the bridge goes to sleep
