Trying to install Entware but usb drive is readonly (R7800)
R7800 uses old version of mount cmd. Old version of mount can only mount usb/partition read-only with metadata_csum feature enabled. Disable Metadata-Checksum.
Format Ext4:
mkfs.ext4 -L <name> /dev/sda1
Disable Metadata-Checksum:
tune2fs -O ^metadata_csum /dev/sda1
Mount Read/Write:
mount /dev/sda1 /mnt/sda1/
Unmount:
umount /mnt/sda1/
Mount Readonly:
mount -r /dev/sda1 /mnt/sda1/
You can use below cmd to check if "metadata_csum" feature is enabled by "mkfs.ext4" cmd on the usb:
tune2fs -l /dev/sda1 | grep features
Format Ext4:
Mount Read/Write:
Unmount:
umount /mnt/sda1/
Mount Readonly:
Thanks for your help. It appears "metadata_csum" is disabled. I'm unable to umount the filesystem when login as "Admin"! Do I need to login as "Root" but I don't know the password. Please see screenshot below
Did you disable the "metadata_csum" or it was already disabled?
Try to force unmount usb:
umount -f /mnt/sda1/
If force unmount does not work unplug the usb. Check if usb is still mounted with cmd "ls -l /mnt/" [OR] "df -h" [OR] "mount | grep sda1". If it is, router reboot is needed with usb unplugged. Plug the usb in after router is rebooted.
It seems like you are using telnet to login to R7800. Enable ssh access from Voxel's readme. It uses root user by default using key based authentication.
airjordanorbi Orbi RBR40 magenta after trying to flash to RBS40 NETGEAR AC Wireless (Wi-Fi 5) 0
