QuikSilver
Woke up this morning to find that I had no internet, tried to log into router to find that it had reset itself to factory default (192.168.50.1). Luckily I had backups and was able to get thing up quickly but I would like to know if this was something that could have been prevented. Out of NVRAM possibly??
Jul 28 22:12:02 RT-AC86U-AEA8 FlexQoS: No TC modifications necessary
Jul 28 22:16:13 RT-AC86U-AEA8 kernel: bcm63xx_nand ff801800.nand: timeout waiting for command 0x1
Jul 28 22:16:13 RT-AC86U-AEA8 kernel: bcm63xx_nand ff801800.nand: intfc status f00000e0
Jul 28 22:19:04 RT-AC86U-AEA8 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Jul 28 22:21:00 RT-AC86U-AEA8 kernel: bcm63xx_nand ff801800.nand: timeout waiting for command 0x1
Jul 28 22:21:00 RT-AC86U-AEA8 kernel: bcm63xx_nand ff801800.nand: intfc status f00000e0
Jul 28 22:39:39 RT-AC86U-AEA8 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Jul 28 22:57:02 RT-AC86U-AEA8 (unbound_log.sh): 16221 Processed 0 reply_domains...
Jul 28 22:57:02 RT-AC86U-AEA8 (unbound_log.sh): 16221 Processed 0 nx_domains...
Jul 28 22:57:05 RT-AC86U-AEA8 (unbound_log.sh): 16221 Processed 0 RPZ events...
Jul 28 23:02:43 RT-AC86U-AEA8 kernel: bcm63xx_nand ff801800.nand: timeout waiting for command 0x1
Jul 28 23:02:43 RT-AC86U-AEA8 kernel: bcm63xx_nand ff801800.nand: intfc status f00000e0
Jul 28 23:07:32 RT-AC86U-AEA8 kernel: htb: htb qdisc 13: is non-work-conserving?
Jul 28 23:09:37 RT-AC86U-AEA8 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
May 5 01:05:12 kernel: nand: Could not find valid ONFI parameter page; aborting
May 5 01:05:12 kernel: brcmboard registered
May 5 01:05:12 kernel: genirq: Flags mismatch irq 36. 00000000 (brcm_36) vs. 00000000 (brcm_36)
May 5 01:05:12 kernel: pci 0000:00:00.0: of_irq_parse_pci() failed with rc=-22
May 5 01:05:12 kernel: pci 0000:01:00.0: of_irq_parse_pci() failed with rc=-22
May 5 01:05:12 kernel: pci 0001:00:00.0: of_irq_parse_pci() failed with rc=-22
May 5 01:05:12 kernel: pci 0001:01:00.0: of_irq_parse_pci() failed with rc=-22
May 5 01:05:12 kernel: broadcomThermalDrv brcm-therm: init (CPU count 2 2 2 2)
May 5 01:05:12 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link UP 100 mbps full duplex
May 5 01:05:12 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) Link UP 100 mbps full duplex
May 5 01:05:12 kernel: eth3 (Ext switch port: 2) (Logical Port: 10) Link UP 1000 mbps full duplex
May 5 01:05:12 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link DOWN.
May 5 01:05:12 kernel: eth3 (Ext switch port: 2) (Logical Port: 10) Link DOWN.
May 5 01:05:12 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) Link DOWN.
May 5 01:05:12 kernel: eth0 (Int switch port: 3) (Logical Port: 3) Link UP 1000 mbps full duplex
May 5 01:05:12 kernel: hub 1-0:1.0: config failed, hub doesn't have any ports! (err -19)
May 5 01:05:15 acsd: selected channel spec: 0x1003 (3)
May 5 01:05:15 acsd: Adjusted channel spec: 0x1003 (3)
May 5 01:05:15 acsd: acs_set_chspec: 0x1003 (3) for reason APCS_INIT
May 5 01:05:16 acsd: selected channel spec: 0xe02a (36/80)
May 5 01:05:16 acsd: Adjusted channel spec: 0xe02a (36/80)
May 5 01:05:16 acsd: acs_set_chspec: 0xe02a (36/80) for reason APCS_INIT
May 5 01:05:26 Mastiff: init
May 5 01:05:26 wsdd2[1557]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
May 5 01:05:29 wsdd2[1557]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
May 5 01:05:42 modprobe: module scsi_wait_scan not found in modules.dep
May 5 01:05:42 modprobe: module uas not found in modules.dep
May 5 01:05:42 modprobe: module mbcache not found in modules.dep
May 5 01:05:42 modprobe: module jbd not found in modules.dep
May 5 01:05:42 modprobe: module ext3 not found in modules.dep
May 5 01:05:42 modprobe: module ext4 not found in modules.dep
May 5 01:05:42 modprobe: module ext2 not found in modules.dep
May 5 01:05:42 modprobe: module btusbdrv not found in modules.dep
Jul 29 09:27:36 RT-AC86U-AEA8 disk_monitor: Finish
Jul 29 09:27:36 RT-AC86U-AEA8 custom_script: Running /jffs/scripts/service-event-end (args: restart diskmon)
Jul 29 09:27:36 RT-AC86U-AEA8 start_ddns: update WWW.ASUS.COM [email protected], wan_unit 0
Jul 29 09:27:37 RT-AC86U-AEA8 disk_monitor: be idle
Jul 29 09:27:37 RT-AC86U-AEA8 inadyn[3900]: In-a-dyn version 2.7 -- Dynamic DNS update client.
Jul 29 09:27:37 RT-AC86U-AEA8 kernel: ERR: bdmf_attrelem_add_as_buf#4250: ucast: status:Entry already exists. attribute:flow index:4294967295
