TUF-BE9400 future support
GoNz0
Searching the entire forum, not just the Merlin section shows 3 results and not one mention of firmware, will this be supported in future releases?
Your question is addressed in the pinned/tacked/stickied post at the top of this subforum: [FAQ] READ ME FIRST before posting a question
Q: Will you add support for model XYZ?
A: The decision whether or not to support a new model depend on a long list of factors, which may evolve over time. Right now:
- It needs to be Broadcom-based
- It needs to be widely available (not just in two or three countries)
- It needs to have high-end hardware so I don't have to fight with lack of flash or RAM
- It needs to receive frequent enough GPLs so I won't have to regularly skip it due to the GPL being outdated
- I need to have one
- I need to have the time to try supporting it
- I need to have the motivation to try supporting it
Each new model requires its own dedicated support. That means every time I work on a new firmware release, I have to work on each separate model, and I need GPL releases from Asus for each individual model, and I need to merge each of them separately. So that means if I support 10 different routers, then I need to merge in the content of 10 different GPL releases, and these need to be close enough to one another to still be compatible. The more models I support, the harder this is to accomplish, therefore I am VERY conservative regarding adding any new model.
So don't ask if/when a new model will be supported. I cannot speculate about future model support, and until I have working support for a model, I cannot answer that question.
Supported Asus-Merlin routers: https://www.asuswrt-merlin.net/about
Supported GNuton Routers: https://github.com/gnuton/asuswrt-merlin.ng
TUF-BE9400 is based on Qualcomm IPQ5322 chipset. FYI, RT-BE90U / RT-BE9400 is also based on a very similar design, but with a different housing / heatsink and DDR4 ram (switched from Samsung to Nanya).
It will be a no then, it's only for my mesh so no problem for me, I couldn't even see what chipset it was as I put it straight as a node so no access to the system info page.
Thanks.
