TUF Gaming AX3000 latest firmware 2.4GHz issue
rickysuper
I have a TUF Gaming AX3000 got 2.4Ghz disconnect problem with my TP-Link HS100 smart plug with both latest FW_TUF_AX3000_300438645934 firmware and previous version FW_TUF_AX3000_300438645898 firmware, only fix is set the 2.4Ghz mode to 'Legacy' mode not 'Auto' or 'N only'. But legacy 2.4Ghz does not support my other 2.4Ghz devices. Revert to firmware version FW_TUF_AX3000_300438643406 fix this issue without NVRAM reset or change any configurations.
Anyone has this 2.4Ghz issues with the latest firmware?
John Fitzgerald
I'm guessing here, but try N only and uncheck B/G protection and hit Apply.
You will loose B/G so legacy devices are out and it may not toggle back without a full reset. (Warning)
John Fitzgerald
Tried but not work, only legacy mode work. I think it got issues with the N mode.
Did you go back to a previous Firmware to rule out a broken 2.4 Radio?
John Fitzgerald
I went back to the third last version of the firmware and problems gone.
Any updates (firmware or software) for the TP-Link HS100?
