Are you sure you've attached the correct log file. I see only one reboot over 6 days and that appears to have been initiated from the GUI.... has random but frequent reboots.
I have two AC68's in mesh acting as AP's, one connected to a fiber modem via powerline adapter.
The second AC68 (both have Merlin's latest) has random but frequent reboots.
Log included for help.
YesISP gateway <powerline> AC68U AiMesh root node in AP Mode <wireless> AC68U AiMesh node
Did you reset the root node firmware before configuring it for AP Mode?
A few times.Have you tried removing/resetting the node and adding it back to the root node configuration?
It has been troublesome for periods. I usually can reset, reconnect as mesh node, and its much more stable, until this time. Has not improved on those resetsHas that node always been troublesome or just recently?
Directly into a new outlet in a new bedroom. Same as always.
Does it have stable power?
None.Does it have wired clients connected to it? If so, does it continue to reboot with those cables disconnected?
Did that once previously, with improvements. Have not tried this time around, wondering if Im getting close to my end of useful life on these.If you swap it with the root node, does the issue follow it?
Welcome To SNBForums
