Two Addons tabs
gjf
Hi.
After update to Merlin 386.1_2 I can see two Addons tabs in menu with the same content and functionality.
Why and how to fix it?
Hi.
Have you rebooted?
So - any more ideas?
Can installed addons affect this behaviour? If so - I have the following ones installed:
check the contents of /jffs/scripts/services-start and /jffs/scripts/post-mount
Is anything duplicated?
After a reboot, please post a complete copy of your system log so I can check for any of my scripts running twice/concurrently
#!/bin/sh
/jffs/scripts/EZprinterRestartLoop.sh &
service stop_lpd
#RC='/opt/etc/init.d/rc.unslung'
#i=30
#until [ -x "$RC" ] ; do
# i=$(($i-1))
# if [ "$i" -lt 1 ] ; then
# logger "Could not start Entware"
# exit
# fi
# sleep 1
#done
#$RC start
/jffs/scripts/YazFi startup & # YazFi
cru a logrotate "5 0 * * * /opt/sbin/logrotate /opt/etc/logrotate.conf >> /opt/>
/jffs/scripts/YazDHCP startup "$@" & # YazDHCP
cru a root_servers "12 4 * * * curl -o \/opt\/var\/lib\/unbound\/root\.hints h>
cru a ytadblock "*/5 * * * * /opt/var/lib/unbound/adblock/gen_ytadblock.sh" >
cru a flexqos "30 3 * * * /jffs/addons/flexqos/flexqos.sh -check" # FlexQoS Add>
#!/bin/sh
swapon /tmp/mnt/swapusb/myswap.swp # Added by amtm
# /jffs/scripts/post-mount
if [ "$1" = "/tmp/mnt/swapusb" ] ; then
# set up and run Entware
ln -nsf $1/entware /tmp/opt
logger "$0:" "Enabling swap on /tmp/mnt/swapusb/myswap.swp"
logger "$0:" "Running rc.unslung to start Entware services ..."
/opt/etc/init.d/rc.unslung start
#/jffs/scripts/EZprinterRestartLoop.sh &
#service stop_lpd
# Below is the content of services-start file
# In fact services-start is obsolete and could be deleted
# But you should move the content here
fi
# This part corresponds to spin down mechanism
# Put it in the very end of your post-mount file
# HDD is the path to HDD disk to be spinned down
HDD=/mnt/HSH_HDD
DISKEXCLUDE=abcdefghijklmnopqrstuvwxyz
DEVICE=$(mount | grep $HDD | cut -f 1 -d " ")
killall -q - sd-idle-2.6
sleep 10
sd-idle-2.6 -i 900 -c 30 -d !${DISKEXCLUDE//${DEVICE:7:1}/}
/jffs/scripts/connmon startup "$@" & # connmon
/jffs/scripts/spdmerlin startup "$@" & # spdMerlin
/jffs/scripts/ntpmerlin startup "$@" & # ntpMerlin
/jffs/scripts/uiScribe startup "$@" & # uiScribe
/jffs/scripts/scmerlin startup "$@" & # scMerlin
/jffs/addons/unbound/unbound_stats.sh startup # Unbound_Stats.sh
Here we go.
Also I have to report that during this very reboot no addons were displayed at all.
But after a while I have reloaded the page and one Addons tab appeared.
Seems the situation got to normal, will investigate more.
I guess I found the source of the problem: it was an update from amtm. Looks like reboot was necessary to complete those update otherwise two tabs case happens.
So the case's closed.
