two asus routers one as access point
HackitZ
hi all.
I have an asus rt-n66u as my main router, i would like to set up my old asus rt-n16 as an access point and be able to use both the wireless and ethernet ports of the rt-n16 router.
i did have dd-wrt on my rt-n16 and used this guide to set up dd-wrt.
how can i do the same set pu running merlins build?
Thanks for any help.
hi all.
I am running the configuration you are asking for (see my footer).
The way forward is simple: Install the latest Merlin firmware (even Beta is good) and configure the RT-N16 as Access Point. Done! Works great for me! :rolleyes:
With kind regards
Joe :cool:
yeah i tried that but the lan ports seem to be disabled and i use them for security cameras.
unless i did something wrong?
Currently I have connected the LAN cable to the WAN port, but earlier it worked also connected to the LAN port.
I have not tried to use the LAN ports for other devices, but I assume that the LAN switching would work in AP mode... :rolleyes:
At least the WLAN to LAN switching worked in my case.
With kind regards
Joe :cool:
