TWO AX92U OPENVPN TAP -NO WORK STB IPTV TRAFFIC MULTICAST/IGMP-
Fardao
Hello friends,
I have two ax92u routers with firmware asuswrt-merlin by genuton from GitHub
MY HOUSE
ISP ROUTER 192.168.1.1
AX92U Server LAN 192.168.100.1
OPENVPN SERVER TAP
daemon ovpn-server1
server-bridge 192.168.100.1 255.255.255.0 192.168.100.200 192.168.100.254
proto udp4
multihome
port 1194
dev tap21
txqueuelen 1000
data-ciphers AES-256-GCM:AES-128-GCM:AES-256-CBC:AES-128-CBC
data-ciphers-fallback AES-128-CBC
auth SHA512
keepalive 15 60
verb 3
client-config-dir ccd
client-to-client
route 192.168.100.1 255.255.255.0
push "route 192.168.100.1 255.255.255.0"
push "dhcp-option DNS 1.1.1.1"
push "dhcp-option DNS 1.0.0.1"
push "dhcp-option DNS 192.168.100.1"
push "route-gateway 192.168.100.1"
push "redirect-gateway def1"
tls-auth static.key 0
plugin /usr/lib/openvpn-plugin-auth-pam.so openvpn
ca ca.crt
dh dh.pem
cert server.crt
key server.key
script-security 2
up 'ovpn-up 1 server'
down 'ovpn-down 1 server'
status-version 2
status status 5
SECOND HOUSE
AX92U Client LAN
192.168.50.1
client
dev tap
;dev-node MyTap
proto udp
remote DNS.NO-IP.COM 1194
resolv-retry infinite
nobind
float
ncp-ciphers AES-256-GCM:AES-128-GCM:AES-256-CBC:AES-128-CBC
auth SHA512
keepalive 15 60
auth-user-pass
remote-cert-tls server
<ca>
</ca>
<cert>
</cert>
<key>
</key>
<tls-auth>
</tls-auth>
key-direction 1
The client manages to have a public IP of my house but no trace of the multicast/igmp traffic to see the iptv in the STB
Any idea?
