dlandiss
I am having some difficulties configuring the WDSync software for a WD My Cloud network-attached hard drive storage box. WD tech support told me to "download and install the UPnP Wizard to determine the external ports assigned to the My Cloud by your router. My Cloud devices with the most recent firmware updates external UPnP port assignment should be between 9000 and 9999."
So I did that and it reports this about my RT-AC68U running John's Fork firmware:
UPnP My Cloud ports:
WD2go 192.168.1.9 / 71.11.107.116, TCP, internal 9091, external 80
WD2soSSL 192.168.1.9 / 71.11.107.116, TCP, internal 9444, external 443
So what really are typical port assignments? Is my installation fouled up, or did WD get it backwards?
Thank you!
Thank you!
