Notconnected
Hi everyone.
I am thinking of purchasing this switch Ubiquiti Pro Max 16 12x1G 4x2.5G 180W L3
And I have a few questions.
Can I login to configure this switch via a browser and ethernet cable, without having to use the internet, cloud apps, or apps that run on a phone.
Also, can it do inter vlan linking.
I am no good at networking, this will be my attempt at setting up a home network and finding cheap
enough Level 3 devices is not easy.
I want vlans to separate my devices into groups. I need some 2.5gig connections, which this switch has
four off, and two more if I use the SFT+ connections.
Am I right in thinking this switch can provide this.
Do I need a buy a lisence every year to make this switch work.
Can I connct this switch to a router and have internet access.
Can I use this switch directly to access the internet, via a wireless adapter plugged in and bridged to a phone or a WiFi Router.
Sorry for all the stupid question but I have never done this before.
Also, can the lights be turned off, I do not like them other than for diagnostics then out with them if possible
This switch is not too long out, but long enough for people to have it in their use, look forward to hearing your opinions, thanks.
Or would this be a better option, it has a fan though,
Mikrotik CRS310-8G 2S IN
