Hello all! New to SNB Forums and Just installed Merlin on my RT-AX88U after some insane DNS issues on Stock firmware.
Anyway, now that my router is useable, I noticed that I am unable to enable any features (AIProtect, Apps Analysis, QOS, If it has a toggle, you bet it won't work) via the "ON" switch in the WebUI. I've tried the following.
Factory Reset
Flash from Recovery
Setting options via NVRAM Variable (Although they stick at first, options in WebUI don't change, and the NVRAM variable resets after reboot)
Strangely, other things such as changing DNS servers and enabling SSH work great.
Any help or insight would be greatly appreciated!
Factory Reset
Flash from Recovery
