petesouthwest
Hi
I've bought an Asus DSl-N16 as it has QoS settings that I need. I'm with Sky, so simply changing the Sky Hub for the new router is not easy as Sky won't give out passwords etc.
So I've read that I should be able to connect the new Asus router to Sky Hub by ethernet cable, disabling the Asus's DHCP and assigning it a fixed IP of 192.168.0.2 and then connecting my other devices to the Asus. AIU my old Sky Hub then does DHCP and works as a modem while the Asus acts like a more intelligent router.
The Asus initial admin panel log on IP is 192.168.1.1 which I can access with a PC connected directly to the router. My Sky Hub admin is 192.168.0.1
However, when I follow the process above and change the Asus to 192.168.0.2 I get an error message saying "192.168.0.2 refused to connect." I get the same message when I connect the Asus to the sky Hub and try that address.
It would be great if anyone could suggest what I'm doing wrong or point me in the right direction.
Many thanks
Many thanks
