Unable to ping anything on GW or LAN after Openvpn connects
mobileman88
I am unable to ping anything on the LAN or GW after OpenVPN connects although there were no errors and I got an IP in the remote LAN. The only IP I could ping is the assigned IP from Openvpn.
This is the config I took from another working OpenVPN which is run from command line in DDWRT, the only thing I changed was that the tap device needed to be "tap21" in Asus-Merlin as per "ls -l" in
"/proc/sys/net/ipv4/conf" after I did a "modprobe tun"
Server
port 1194
proto udp
dev tap21
ca ca.crt
cert server.crt
dh dh2048.pem
ifconfig-pool-persist ipp.txt
server-bridge 192.168.20.2 255.255.255.0 192.168.20.221 192.168.20.240
push "route 192.168.20.0 255.255.255.0"
push "route 192.168.21.0 255.255.255.0"
keepalive 10 60
tls-auth ta.key 0
persist-key
persist-tun
verb 0
mute 5
Client
client
dev tap
dev-node "Local Area Connection 3"
proto udp
remote remote.hostname.com 1194
resolv-retry infinite
nobind
persist-key
persist-tun
ca ca.crt
cert client.crt
key client.key
ns-cert-type server
tls-auth taClient.key 1
verb 1
Any particular reason why you use TAP instead of TUN? It adds overhead and potential complexity to your network, especially if both networks have their own DHCP server.
I also use TAP.. when using TUN, I found out I can't browse all the network.
When using TAP, all clients in the network are accessible from every client and vice versa..
If you know a setup for TUN to do this as well, let me know. I'm willing to experiment.
But if you need a "open" setup for all clients inside the network..use TAP.
My setup: 1 openVPN Server, using TAP with a 172.22.56.0 network behind it.
And then 9 Client openVPN, using TAP, with a 172.22.57.0 to 172.22.65.0 networks behind it..
All clients are DD-wrt routers.. and they use TAP to connect complete networks alltogether.. not just single clients..
I use TAP so that I can see the entire network without having to handle additional routing rules. Moreover, this config has been working for DDWRT <-> DDWRT and also DDWRT <-> OpenVPN clients (windows/tablets etc) for the past few years. All I did was copy over the certificates and the config file and execute it on the Asus-Merlin firmware. Only thing I changed was to use "tap21" as that seems to be the only TAP device available for me to use.
Could you pm me your config on ASUS-Merlin? I am able to connect and get an IP successfully but not able to do anything else.
I tried adding the tap21 interface to my br0 bridge but I am still unable to ping anything other than my VPN client's IP address.
Licked the problem. Issue is with ISP supplied router in front of my ASUS, it is still redirecting traffic to my old router! What a PITA.
Being far from the expert, this helped me decide: https://community.openvpn.net/openvpn/wiki/BridgingAndRouting
I guess the TUN/TAP depends on what you want. I have router to router OVPN setup working wonderfully with TUN. I've set all of my PC's, and other devices to static internal IP's. That way I KNOW where everything is at with the different sites. I find it actually preferable in my case, since I don't want my other sites browsing the network. (snooping around)
mRemoteNG has helped tremendously in organizing access to different network resources...
I guess the TUN/TAP depends on what you want. I have router to router OVPN setup working wonderfully with TUN. I've set all of my PC's, and other devices to static internal IP's. That way I KNOW where everything is at different sites. I find it actually preferable in my case, since I don't want my other sites browsing the network. (snooping around)
Great tip. Thanks!
