Unable to Route Clients Through VPN From Guest Network 1
maddog28
First post on here, been following for years and found most answers.
Running 4b on AX88U and unable to route Guest Network 1 clients through the VPN. In OpenVPN, set to strict policy routing and set the entire guest network 1 subnet (since guest 1 gives an entirely new subnet) to route through VPN. Unfortunately, after setting this policy rule, all guest clients get blocked from accessing the internet at all.
Even when specifying specific clients on the guest network to route through the VPN, internet access is blocked for those specified guest clients.
When using guest network 2, everything works as advertised.
I am running a mesh network and I want clients that are farther away to connect to the mesh node guest network and then through the VPN for added security.
While I am assuming that the new subnet and guest 1 have something to do with it, just wanted to run it by the experts here to get your thoughts.
Thanks for any assist!
If I had to guess, Asus' new guest implementation creates a new bridge, and policy routing applies to br0. you could try running something like
ip route add 192.168.51.0/24 dev br1 proto kernel table ovpnc1 src 192.168.51.1
to see if this helps. replace the IP subnet and ovpnc1 accordingly (ovpnc1 being client 1)
EDIT: I'm hoping to make YazFi AiMesh 2.0 compatible for syncing Guest 1 to nodes once 386 is stable, so you won't need to worry about command line stuff if I'm successful :)
Thanks for the command line. I put that in and no response from Putty (not sure if one is given, new to SSH). Tried to route the clients and the same issues as OP.
