I have been playing with it on my RPI.... It is nice.....Entware is still only publishing 1.11. OpenWRT has pushed 1.12, so Entware should pick it up in the next quarterly update.
or someone could ask the devs to prioritize an update on their Telegram...Entware is still only publishing 1.11. OpenWRT has pushed 1.12, so Entware should pick it up in the next quarterly update.
How so? what does the update bring?I have been playing with it on my RPI.... It is nice.....
I don't think it really warrants an out-of-band release on Entware, personally. 1.12 brings DoH on the client side, so you could theoretically (or academically) have your LAN clients do DoH to Unbound. Only useful if you snoop on yourself on the LAN.or someone could ask the devs to prioritize an update on their Telegram...
here is the change logor someone could ask the devs to prioritize an update on their Telegram...
This release contains the DNS Flag Day 2020 changes. This sets the default EDNS buffer size to 1232, that should reduce fragmentation.
https://dnsflagday.net/2020/
There is inclusive language in the configuration. There is caps-exempt, ipsecmod-allow and primary server options for auth-zones. The older terms are accepted to keep configuration working.
DNS-over-HTTPS is supported in this release. The DoH is enabled when Unbound is compiled with the nghttp2 library, with configure --with-libnghttp2. Then have an interface on the https port, that can be configured with the https-port option. Also have a cert and key available with the tls-service-key and tls-service-pem options. Further settings can be configured for the http-endpoint, http-max-streams, http-query-buffer-size, http-response-buffer-size and http-nodelay options. The max streams sets the maximum concurrent streams, the buffer size options the number of bytes in buffers, and the nodelay option can turn on TCP_NODELAY for DNS-over-HTTPS service. In the statistics the memory used is reported in mem.http.query_buffer and mem.http.response_buffer. The number of queries is reported in num.query.https, they are also included in the tcp and tls counts because https uses TLS and TCP.
The DLV options and code to handle DLV lookups have been removed from the code base. The DLV repository is empty nowadays, it has been decommissioned.
There is a new feature where it is possible to use interface names to bind to the IP addresses on that interface. It pulls in the addresses at the start of the server, if the addresses change, use the existing freebind and other socket options to register for addresses before they appear, or the interface-automatic option that copies them from queries to answers with ancillary data.
There is a new option for the edns-tag draft specification. It can be enabled if you need the tentative implementation to add those tags to outgoing messages.
Features
- DNS Flag Day 2020: change edns-buffer-size default to 1232.
- Merge PR #255: DNS-over-HTTPS support.
- Use inclusive language in configuration
- Merge PR #284 and Fix #246: Remove DLV entirely from Unbound.
The DLV has been decommisioned and in unbound 1.5.4, in 2015, there
was advise to stop using it. The current code base does not contain
DLV code any more. The use of dlv options displays a warning.
- Similar to NSD PR#113, implement that interface names can be used,
eg. something like interface: eth0 is resolved at server start and
uses the IP addresses for that named interface.
- Merge PR #272: Add EDNS client tag functionality.
- Add edns-client-tag-opcode option
Bug Fixes
- Merge PR #270 from cgzones: munin plugin: always exit 0 in autoconf
- Merge PR #269, Fix python module len() implementations, by Torbjörn
Lönnemark
- Merge PR #268, draft-ietf-dnsop-serve-stale-10 has become RFC 8767 on
March 2020, by and0x000.
- Fix doxygen comment for no ssl for tls session ticket key callback
routine.
- Fix mini_event.h on OpenBSD cannot find fd_set.
- Improve error log message when inserting rpz RR.
- Merge PR #280, Make tvOS & watchOS checks verify truthiness as well as
definedness, by Felipe Gasper.
- contrib/aaaa-filter-iterator.patch file renewed diff content to
apply cleanly to the current coderepo for the current code version.
- Fix #287: doc typo: "Additionaly".
- Merge (modified) PR #277, use EVP_MAC_CTX_set_params if available,
by Vítězslav Čížek.
- Create and init edns tags data for libunbound.
- Fix stats double count issue (#289).
- Fix that dnstap reconnects do not spam the log with the repeated
attempts. Attempts on the timer are only logged on high verbosity,
if they produce a connection failure error.
- Fix to apply chroot to dnstap-socket-path, if chroot is enabled.
- Change configure to use EVP_sha256 instead of HMAC_Update for
openssl-3.0.0.
- Update documentation in python example code.
- Review fix interface, doxygen and assign null in case of error free.
- Merge PR #293: Add missing prototype. Also refactor to use the new
shorthand function to clean up the code.
- Refactor to use sock_strerr shorthand function.
- Fix #296: systemd nss-lookup.target is reached before unbound can
successfully answer queries. Changed contrib/unbound.service.in.
- Fix num.expired statistics output.
- Remove x file mode on ipset/ipset.c and h files.
- Spelling fix.
- Introduce test for statistics.
- Fix that prefer-ip4 and prefer-ip6 can be get and set with
unbound-control, with libunbound and the unbound-checkconf option
output function.
- Merge PR #311 by luismerino: Dynlibmod leak.
- Error message is logged for dynlibmod malloc failures.
- iana portlist updated.
- Fix #304: dnstap logging not recovering after dnstap process restarts
- Fix edns-client-tags get_option typo
- Fix #305: dnstap logging significantly affects unbound performance
(regression in 1.11).
- Fix #305: only wake up thread when threshold reached.
- Fix to ifdef fptr wlist item for dnstap.
- Fix memory leak of edns tags at libunbound context delete.
- Fix double loopexit for unbound-dnstap-socket after sigterm.
I vote to wait for v1.131.13.0 is already in release candidate to address SAD vuln and add tcp reuse for upstream servers (e.g. DoT).
How "safe" is is it to use Unbound? (vs. not using it)
Since there are always new vulnerabilities popping up.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
